Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1224 Discussions
Error in MinnowBoardMax Platform Guide
FrankVanWeerdenburg
The MinnowBoard Max Platform guide can be found:
https://www-ssl.intel.com/content/www/us/en/embedded/products/bay-trail/atom-e3800-minnowboard-max-platform-guide.html Intel® Atom™ Processor E3800 Product Family MinnowBoard MAX: Platform Guide
Page 10 shows six-pin header J4 to be able to connect to a terminal.
The following text is wrong:
Pin 1 is on the right in Figure 3, furthest away from the SATA port.
It should be:
Pin 1 is on the left in Figure 3, closest to the SATA port.
Based on this error, also the picture (reference Figure 5) on page 12 should be updated.
The black wire (GND pin 1) should be assembled closest to the SATA connector.
For explanation, see below the actual screen dump of the layout of the board.
Frank van Weerdenburg
ELTAN BV - BIOS customization
http://www.eltan.com/ Eltan
CarlosAM_INTEL
Hello FrankWeerdenbur,
Thank you for contacting the Intel Embedded Community.
We really appreciate that you inform us of this situation, but we suggest you to inform the developer of this third party device to correct this information through all the documentation related to this product.
You can use as a reference the channels listed at the following web sites:
/wiki.minnowboard.org/Get_Involved Get Involved - MinnowBoard Wiki
/plus.google.com/ MinnowboardOrg MinnowBoard - Google+
/twitter.com/minnowboard MinnowBoard (@MinnowBoard) | Twitter
/www.facebook.com/pages/MinnowBoard/388667897899215 MinnowBoard
mailto://# minnowboard@irc.freenode.net //# minnowboard@irc.freenode.net
/lists.elinux.org/mailman/listinfo/elinux-minnowboard elinux-MinnowBoard Info Page
We hope that this information is useful to you.
Carlos_A.
FrankVanWeerdenburg
Hello Carlos,
Thank you for your reply.
The information of this third party is correct. For example see:
http://wiki.minnowboard.org/MinnowBoard_MAX_HW_Setup MinnowBoard MAX HW Setup - MinnowBoard Wiki
Only the Intel document as mentioned above, which is listed on an Intel website is wrong.
Frank
