1227 Discussions
Intel Atom CT80618005841ABSLH5M Real Time Clock
JBian1
need some help with the Intel Atom
I am not going to use the RTC and would like to remove the crystal to save PCB space.
Is that ok, or is the crystal needed to drive some other internal function?
If so, please describe.
FMcNu1
Valued Contributor I
Hello
I want to make you aware of a special place to go with questions like yours. The Intel® e-Help desk is staffed by Intel representatives who support select Intel embedded platforms including Intel® Atom™ and associated chipsets.
Here is the link to post your question in e-Help:
http://embedded.communities.intel.com/community/en/intel_e-help_desk/low_power_platforms http://embedded.communities.intel.com/community/en/intel_e-help_desk/low_power_platforms
To access e-Help, you need to be a Privileged member of the Intel® Embedded Community.
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
In addition to access to e-Help, Prvileged members may also access the confidential content within the Intel® Embedded Design Center, such as design documents, specifications, and training materials.
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
