1229 Discussions
Atom N450 board : Is there any Flash memory on this board ?
mmekh
I am using Atom N450 Board, is there any Flash memory on it ? if yes, how can i detected it ?
Remark:
There is no Flash memory information in the data sheet.
Thank you.
FMcNu1
Valued Contributor I
Hello
Here are a few things that might help answer your question,
In case you have not already found it, here is the user manual for the devboard:
http://download.intel.com/embedded/devkits/323431.pdf http://download.intel.com/embedded/devkits/323431.pdf
And here is a discussion thread containing FAQs for the devboard. Note the first 2 questions deal with Flash:
http://embedded.communities.intel.com/thread/4876 http://embedded.communities.intel.com/thread/4876
If these resources do not answer your question, you might want to access e-Help. The Intel® e-Help desk is staffed by Intel representatives who support select Intel embedded platforms including Intel® Atom™ and associated chipsets.
To access e-Help, you need to be a Privileged member of the Intel® Embedded Community.
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
In addition to access to e-Help, Prvileged members may also access the confidential content within the Intel® Embedded Design Center, such as design documents, specifications, and training materials.
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
