1239 Discussions
PLEVT 1.13.3 gives mount error when trying to save results to a USB drive
UGuth
I'm performing margin tests on a Atom C3000 system - works quite nice, but I can't save any results on the USB stick(s) (which the software basically does recognize) nor am I able to save a PCI register dump.
I do always get a mount error like this:
/dev/sda1: invalid argument
/dev/sda: invalid argument
I am running the software from EFI shell on a USB stick.
How can I resolve this problem?
Thank you very much in advance!
Kind regards,
Uwe
CarlosAM_INTEL
Hello, @UGuth​:
Could you please confirm that you are following the guidelines stated in the Intel Atom Processor C3000 Product Family Validation Guide document # 595579? It can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/595579.htm
The RDC Account Support form is the channel to process your account update request or any inconvenience related to the provided website. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
We are waiting for your answer.
@Mæcenas_INTEL​.
UGuth
Hello @Mæcenas_INTEL,
Thank you very much for your answer - confirmed. Although the document you mentioned does not say a single word about saving anything to a USB stick. ;-)
Uwe
CarlosAM_INTEL
Hello, @UGuth​:
Thanks for your reply.
Could you please confirm if this situation happens with any of the following Operating Systems? In case that the affected Operating System (OS) is not on this list, please try to reproduce the situation using any of the following OS and let us know the outcomes of this suggestion.
  • Microsoft Windows Server 2016 (including Nano Server), Server 2012 R2
  • Linux KVM (RHEL 7.3, 7.4)
  • VMware ESXi 6.0
  • Microsoft Windows Hyper-V
  • Xen 4.9
  • Red Hat Enterprise Linux 7.3, 7.4
  • SUSE Linux Enterprise Server 12 SP3
  • Ubuntu 16.04, 16.10, 17.04 LTS
  • Yocto Linux 2.1
  • CentOS 7.3
  • Wind River Linux WRL8, WRL9
Could you please clarify if this situation happens with a specific USB device or various, also if this condition is related to a specific USB port or various? In case that you ignore the answer, please try to reproduce this condition using different USB devices, ports, and let us know the results in detailed way.
@Mæcenas_INTEL​.
UGuth
Hello @Mæcenas_INTEL (Intel)​,
I've tried a whole bunch of USB Sticks using Windows 10 x64 and Ubuntu 17.4. They all work flawlessly on all ports. However, no matter which stick is plugged into which port, PLEVT seems to recognize it - it appears in the list - but it seems to be impossible to mount it.
The sticks use FAT or FAT32 file system.
Mounting the stick and saving data works fine with PLEVT 1.12.7, 1.13.1, 1.13.2.
Uwe
CarlosAM_INTEL
Hello, @UGuth​:
We suggest you address your questions related to the cited at the channels listed at:
https://designintools.intel.com/Support-a/250.htm
@Mæcenas_INTEL​.
UGuth
Thank you very much! :-)
Uwe
