1230 Discussions
The Intel Media SDK is unable to decode a stream of raw H264 video from a camera. Is Media SDK suitable for streaming applications?
dmotw1
Hey,
I am trying to decode an H264 video stream coming in from the camera but I keep getting ERR_MORE_DATA and it is never able to reach to the decoding phase of the code.
Platform:
Intel Atom E3950 (Apollo Lake)
OS:
Ubuntu 16.04 LTS
Steps Taken:
The setup required to run the Media-SDK is done by following documentation:
https://software.intel.com/en-us/articles/build-and-debug-open-source-media-stack
I am also able to run the sample projects provided on git successfully. Specifically, the sample_decode example is able to take in the raw H264 file and spit out the YUV format. This makes me assume there is no issue with missing drivers from Intel.
I also pulled the "decode" sample from tutorial and was able to run that and used it as my reference which I found at the following link:
https://software.intel.com/en-us/articles/media-sdk-tutorials-for-client-and-server
I also read the steps required to setup the Media SDK on the following link:
https://software.intel.com/en-us/articles/framework-for-developing-applications-using-media-sdk
Problem:
But none of this works. When I run my code the MFXVideoSession_DecodeHeader(Session, &Bitstream, &Videoparam) returns ERR_MORE_DATA. The buffer that is being passed has around 32000 bytes of data, I was able to check this value in the debugger. And the code is never able to get to the point of decoding phase and stays stuck here.
How can I solve this problem?
I am not sure if the intel Media SDK supports real time decoding and I would like more insight on that too.
Note:
The API version that I am able to query in the code gives me that it has Version 1.28. The repository was cloned from github a month back.
CarlosAM_INTEL
Hello, @dmotw1​;
In order to be on the same page, could you please confirm that this thread is the same as the one stated in the following website?
https://forums.intel.com/s/question/0D50P00004HLBiDSAX/the-intel-media-sdk-is-unable-to-decode-a-stream-of-raw-h264-video-from-a-camera-is-media-sdk-suitable-for-streaming-applications
Waiting for your clarification.
@Mæcenas_INTEL​.
