1223 Discussions
Tizen IVI on Atom E38xx (kernel configuration)
MGuse1
Hello! I prepare kernel 3.10.28 with recomendations from https://www-ssl.intel.com/content/dam/www/public/us/en/documents/guides/tizen-ivi-m2-kernel-ltsi-linux-support-package-atom-e3800-gsg.pdf https://www-ssl.intel.com/content/dam/www/public/us/en/documents/guides/tizen-ivi-m2-kernel-ltsi-linux-support-package-atom-e3800-gsg.pdf (january 2015 revision).
1) In that guide in 3.3.1.4 "cp arch/x86/configs/byt_32_tz_emgd_defconfig .config" and make sure following item is configured to y "CONFIG_DRM_EMGD=y".
2) Next, in 3.4.4.4 process these instructions:
"-Type "make arch=i386 menuconfig".
- Go to > Device Drivers > Multimedia Supports > Intel Atom Image Signal
Processor CSS2.0 Driver (set as "M")
- Save and Exit."
In the second instructions new config file created and all emgd settings are removed. I compared byt_32_tz_emgd_defconfig and .config file after 3.4.4.4. CONFIG_DRM_EMGD string is absent in new .config file.
That config file is more correct, byt_32_tz_emgd_defconfig, or new .config after 3.4.4.4? How prepare config file with settings for emgd and ISP together?
Thanks for any help!
Hello Maks Gusev,
Please try "make byt_32_tz_emgd_defconfig arch=i386 menuconfig", instead of "make arch=i386 menuconfig".
This will use the default config copied to the kernel top directory "cp arch/x86/configs/byt_32_tz_emgd_defconfig .config".
Leon
Hello Maks Gusev,
Welcome back to the Intel® Embedded Community.
We are working on getting an answer to your question. Have a great day and we'll be talking with you soon!
Leon
Gabriel_T_Intel
Hello Maks,
We are working in your case and will contact you with additional information as soon as possible.
Gabriel Thomas
Hello Maks Gusev,
Leon
MGuse1
Hello, Leon.
I recompiled sources using your instructions and this problem is solved now.
