1229 Discussions
Unable to debug UEFI BIOS on a minnowboard max A2 with XDP3
ctang28
Our team using a minnowboard max A2 to develop UEFI BIOS, but the bios hangs after BIOS_RESET_CPL has been written if the XDP3 is attached to the board and Intel System Debugger is connected to XDP3. If we skip the write operation, booting will go on, then hangs at the first time the BIOS try to trigger an SMI using mSmmControl2->Trigger in function SmmCommunicationCommunicate.
The board can boot to OS without any problem if Intel System Debugger is closed, even if XDP3 is attached to the board.
And everything is OK if we connect Intel System Debugger to the board after it boots to Setup or EFI Shell.
so how can we debug the early boot stage?
Our team built the BIOS on a Linux machine with gcc=4.9 following the instructions at https://software.intel.com/en-us/articles/minnowboard-maxturbot-uefi-firmware
Board : minnowboard max A2
JTAG hardware : Intel blue box ITP-XDP 3BR
Debugger: Intel System Debugger legacy 2020
Intel Binary Objects: R1.01
Edk2: UDK2017
CarlosAM_INTEL
Hello, @ctang28​:
The proper channels to handle this third-party device issue should be the listed as a reference on the following website:
https://github.com/tianocore/tianocore.github.io/wiki/Reporting-Issues
@Mæcenas_INTEL​.
ctang28
It seems that there is a watchdog timer, BIOS must write the BIOS_RESET_CPL register as soon as possible, otherwise the watchdog would timeout, and cpu hangs.
BIOS will disable the watchdog timer after programming a lot of base address register.
Neither put breakpoints before BIOS disable the watchdog timer, nor single step from reset vector.
And Intel DO provide a script to disable the watchdog timer, just rename scripts/hooks/target_reset_handler.mbmax.xdb to target_reset_handler.xdb, then the watchdog timer will be disabled automatically when the board resets.
CarlosAM_INTEL
Hello, @ctang28​:
Thanks for your update.
Could you please clarify if the provided information has been solved your problem?
We are waiting for your reply.
@Mæcenas_INTEL​.
ctang28
YES, we can debug the whole boot stage from sec to rt with the TCO disabled
CarlosAM_INTEL
Hello, @ctang28​:
Thanks for share the solution to this situation.
Please do not hesitate to contact us if you have any consultations associated to Intel Embedded devices.
@Mæcenas_INTEL​.
