Where to download the microcode M01406D812A for Intel Atom C2758? The archive downloaded from this link ( https://downloadmirror.intel.com/28087/eng/microcode-20180807a.tgz ) does not contain the desired file 06-4d-8.
You can find the downloads here:
https://downloadcenter.intel.com/product/77988/intel-atom-processor-c2758-4m-cache-2-40-ghz
Doc
Yes, I downloaded this archive but there is no microcode in it that I need. Either something I do not understand. My processor Intel Atom® C2758 ID = 406D8 => the file should be named 06-4d-8 - but there is no such file!
If you are a linux user, the firmware files are on the link I provided.
If not, explain in detail what you want and an Intel support engineer can assist you.
Doc
I need a microcode file to create a bios file based on coreboot. For example, for the atom c3000 (Denverton) I took the file 06-5f-01 from this archive and all work fine. But for atom c2000 (Rangeley) I cannot find the microcode file in that archive. File must called 06-4d-8. Or I am mistaken and the file for atom c2000 is called differently? I work under Linux - please indicate to me which file I should use for atom c2000. Microcode revision should be 0x0000012A.
Hello, @DPona :
The Intel Atom Processor C2000 Product Family Microcode Update document # 527340 has the information that may help you. It can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/527340.htm
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
