Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1223 Discussions
".NET Check failed"? Unattended install Q graphics "Intel HD graphics"
EPatt
Hello, I'm trying to install the Q57 video drivers using an unattended install and it fails every time with the message "Checking .NET configuration" "* .NET check failed"
I do not care about .NET at the point in the build that I am installing the video drivers, how do I tell the setup to shut up and install? Is there a /shutupabout.NETalreadyandinstall switch?
This is for a Windows XP build. I don't want to install .NET since it gets installed later in the process.
FMcNu1
Valued Contributor I
Hello, EricPatterson:
Welcome to the Intel® Embedded Community.
Are you working with an embedded system, or a consumer PC?
If you haven't already done so, you might want to check out this support area for the Q57:
http://www.intel.com/p/en_US/support/highlights/chpsts/5series-chpsts http://www.intel.com/p/en_US/support/highlights/chpsts/5series-chpsts" target="_blank" rel="nofollow">http://www.intel.com/p/en_US/support/highlights/chpsts/5series-chpsts
Felix
