1249 Discussions
what‘s the value range of good CPU from AM42 to GND
YHu11
Our production line feedback that ICT detected Intel MPN: FH8065503553400SR3GZ have differences.
The value between AM42 and GND:
Nomal: more than 6 Ohm
Now: about 3 Ohm
So we want to know what‘s the value range of good CPU from AM42 to GND . Thanks.
Wanner_G_Intel
Hello YHu11,
Thank you for posting your question on this Intel® Community.
To address your inquiry, we would like to have more information about your system configuration.
  • Could you please confirm the processor number?
  • Is Intel Atom® Processor C2538 the processor you are referring to?
  • Could you please provide more details about your request and why you need this information?
Wanner G.
YHu11
 This MPN is FH8065503553400SR3GZ . INTEL ATOM C2538,
Due to our IC test fail. so we want to know what's the range from AM42 to GND.
Wanner_G_Intel
Hello YHu11,
Thank you for your response.
To better assist you, we are moving this thread to the Embedded Intel Atom® Community.
Wanner G.
CarlosAM_INTEL
Hello, @YHu11​:
Based on the information mentioned on your previous communications, could you please give the pictures of the top side markings of the processors associated to this forum?
By the way, could you please give a detailed description of the problem associated to the cited situation?
We are waiting for your answer.
@Mæcenas_INTEL​.
YHu11
The information for component testing is as follows.
The resistance value between VNN_CP to GND
1. Defective sample: 2.79 Ohm
2. Raw material(3 samples) : 6.2 Ohm, 5.8 Ohm,  3.6 Ohm
S/N:2R939511A05098
CarlosAM_INTEL
Hello, @YHu11​:
Thanks for your update.
However, it is unclear part of the top side markings of the provided picture, also there is no indication if the processor is unrelated to the mentioned situation or not.
Due to these facts, could you please provide pictures indicating clearly the status of the processors?
We are waiting for your clarification.
@Mæcenas_INTEL​.
