Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1343 Discussions
Intel Core i9 10900E (Embedded) CPU in a non-embedded motherboard?
R_A_M_
Hey! I wanted to know if a embedded CPU (Core i9-10900E) would work in a non-embedded motherboard? (10900E in a W480 or Z490 for example)
CarlosAM_INTEL
Hello, @R_A_M_:
We want more information to understand your question.
Due to this fact, we want to address the following questions:
Could you please let us know the part number and manufacturer of the cited motherboard? By the way, please inform us where is stated the information of the mentioned motherboard?
Could you please explain the reasons to use the cited processor?
We are waiting for your answer.
@CarlosAM_INTEL.
R_A_M_
I hoping to purchase the i9-10900E for one of the following motherboards. Both motherboards don't have embedded CPU on their support page. Both boards, however, have the i225-LM which is a "embedded" Intel NIC.
- ASRock W480 CREATOR LGA 1200 Intel W480 SATA 6Gb/s ATX Intel Motherboard
- ASUS Pro WS W480-ACE LGA 1200 Intel W480 SATA 6Gb/s ATX Intel Motherboard
AlHill
Caution:  If the proessor is not in the supported processor list from the board manufacturer, IT IS NOT SUPPORTED.
It must be socket, chipset, AND BIOS COMPATIBLE.
CarlosAM_INTEL
Hello, @R_A_M_ :
Thanks for your reply.
You need to address your question for the first motherboard listed in your previous communication, as a reference, by filling out the form stated on the following website:
https://event.asrock.com/tsd.asp
 On the other hand, your question related to the second motherboard mentioned in your previous communication should be addressed, as a reference, by filling out the form stated on the following website:
https://www.asus.com/support/Product/ContactUs/Services/questionform/
@CarlosAM_INTEL.
R_A_M_
Thanks! I will do that.
One other question: What is the all-core turbo of the i9-10900E? I can not find that information about that on the spec sheet. the Intel® Turbo Boost Technology 2.0 Frequency on the spec sheet is "BLANK".
Example: the 10900F has a Intel® Turbo Boost Technology 2.0 Frequency is 5.0GHz. The all-core turbo is 4.6GHz, which is not listed on the 10900F spec sheet.
CarlosAM_INTEL
Hello, @R_A_M_:
Thanks for your update.
You need to review the information stated on pages 12, 13, and 16 of the Comet Lake-S for IoT Platforms - Design In document # 614380, and the note in section 3.3.2, on page 64 of the 10th Generation Intel® Core™ Processors External Design Specification (EDS), Volume 1 of 2 document # 606599. You can find them when you are logged into your Resource & Design Center (RDC) privileged account on the following websites:
https://cdrdv2.intel.com/v1/dl/getContent/614380
https://cdrdv2.intel.com/v1/dl/getContent/606599
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided websites. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
