Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Intel Driver Configuration API
cnewell
I am working with a system that has an Intel i7-9700E w/ a Intel UHD Graphics 630
I am attempting to configure settings, programmatically, that are typically controlled through Intel Graphics Command Center.
Does intel offer an API, similar to the Intel Graphics Control Library? I tried running a sample program from the repo of this library, and the error indicates that the library is not compatible with the system I am working with.
Any help will be appreciated. I will note I do work for an OEM, so if we need specific business agreements, I can coordinate this as well.
Thank you.
Labels (3)
NormanS_Intel
Hello cnewell,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Embedded Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
Diego_INTEL
Hello @cnewell,
You can check the VPL documentation, I hope it helps.
https://www.intel.com/content/www/us/en/developer/tools/vpl/overview.html
@Diego_INTEL
