Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Processor embedded enabled Options
PV
Hi ,
Could you please explain - what is the different between Embedded Options enabled processor and Non embedded Options enabled processor ?
Can we use Non embedded Options enabled processor instead of Embedded Options enabled processor ?
Intel - D-1530 processor is Embedded Options enabled processor or not. i cant find details from datasheet. pls give your comments.
Thanks & Reagrds
Parthiban V
CarlosAM_INTEL
Hello, PARTHIBAN:
The Embedded devices are developed to be used on designs that could be different than computers instead of the non-embedded ones. You may find examples of embedded projects at the following websites:
https://solutionsdirectory.intel.com/?gclsrc=aw.ds https://solutionsdirectory.intel.com/?gclsrc=aw.ds
https://solutionsdirectory.intel.com/solutions-directory/categories/125 https://solutionsdirectory.intel.com/solutions-directory/categories/125
In order to determine the best option for your design, you should analyze the needs that will be solved with your project.
On the other hand, could you please tell us where is stated the "Intel D-1530" Datasheet? Please attach it to your answer.
Please let us know the answer to the previous question.
We really appreciate your cooperation.
Carlos_A.
PV
CarlosAM_INTEL
Hello. PARTHIBAN :
Thanks for your update.
Based on the provided information and the https://ark.intel.com/compare/91203,91196,91200,122998 Intel® Product Specification Comparison tool, for the listed family the Embedded devices available are showed yellow highlighted at the following screenshot:
We hope that this information may help you.
Carlos_A.
PV
Hi Carlos A
Thanks for your answer.
Can we use same family Non embedded Options enabled processor instead of Embedded Options enabled processor for our network server products ?
Thanks & Reagrds
Parthiban V
CarlosAM_INTEL
Hello, PARTHIBAN:
Based on our first communication, we suggest you review the features of each device and determine which is the best option for your design. By the way, you can use the mentioned https://ark.intel.com/compare/91203,91196,91200,122998 Intel® Product Specification Comparison website for this propose.
Also, you can address your last question by filling out the https://plan.seek.intel.com/us_en_embedded_registration-form-contactsaleswebform_html?cp=EDC%20-%20Eval%20Platforms%20Store Intel - Contact Sales form. The team in charge of this channel will be more than glad to help you.
Carlos_A.
