Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Program MAC Address
TFont1
I have to create a batch file to run something like Quartzville Tools in order to program MAC Address' for different units. For each unit it will increment the MAC Address, how could I go about doing this? I know that people used to use Quartzville Tools to do this, but does it still support newer adapters as well?
CarlosAM_INTEL
Hello, Tyler_Fontaine :
We suggest you use the https://edc.intel.com/Link.aspx?id=3815 Intel Network (Quartzville) Connections Tools 21.1 PV LAN Software Tools [05-Oct-2016] document # 348742 to solve this situation.
We hope that this information is useful to you.
Carlos_A.
TFont1
Carlos_A:
In order to program our old chipset we were able to simply run a batch file containing the following:
"eeupdate /NIC=3 /D 82583.txt
eeupdate /NIC=3 /A ADDRESS.DAT
copy eelog.dat ADDRESS.DAT"
Would this same approach work for the I210 Chipset with INVM?
CarlosAM_INTEL
Thanks for your update.
It is important to let you know that the Eeupdate works with all of Intel's current adapters.
We hope that this information may help you.
Carlos_A.
