Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
D1637 availability
YB
Can you help to confirm if the availability/lifecycle of  Intel Xeon D1637 processor is 7 years from launch?
Based on the IOTG Quick Reference Guide document from Resource Design Center, it shows that the availability of this processor is 7 years, however our customer got rumor that it will be EOL in Q1 of 2022 together with D1537 hence they would like to confirm this info.
Kindly help to clarify.
Thank you.
CarlosAM_INTEL
Hello, @YB:
You should review the Product Change Notifications (PCNs) related to the cited product to verify the status of the cited device. You can find them on the following website:
https://qdms.intel.com/Portal/SearchPCNDataBase.aspx?mm=999GZP
You should also verify the availability information of the Intel products with the company where you acquire them or through the Intel Authorized Distributors, which are listed on the following website:
https://marketplace.intel.com/s/pmp-partner-program/a723b0000008PICAA2/distributor
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @YB:
@CarlosAM_INTEL.
YB
Hi Carlos,
Thank you for the info, however the 2 options provided both unable to help.
We just need a confirmation from Intel if the availability of D1637 will continue be 7 years from launch.
Thank you.
CarlosAM_INTEL
Hello, @YB:
Thanks for your reply.
The previous suggestions may give you a formal way to let you know the requested information.
However, you can find the requested information in the attached image, which is stated on page 7 of the  Delivering Leading-Edge Computing Technology to the Public Sector Product Brief that can be found on the following website:
https://www.intel.com/content/dam/www/public/us/en/documents/technology-briefs/edge-computing-technical-brief.pdf
In case that specific information is needed for a specific product, you should follow the last suggestion provided in the email sent to you.
@CarlosAM_INTEL.
