Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
317 Discussions
DDR4 Analysis using MBERE tool
KMANO3
Hello Team,
Note FYI - We are using Broadwell -DE DDR4 Processor Model and for tr0 generation we are using HSPICE P-2019.06-SP1.1.
We have Installed Intel MBERE tool and associate MATLAB* Compiler Runtime (MCR) version 8.0 (R2012b).
While running Intel MBERE we are observed below mentioned error
MBERE_1.4
MBERE Run Completed
ans =
   0
Elapsed time is 0.858452 seconds.
read in data ended:
Reference to non-existent field 'isi_node'.
Error in read_all_tr0_data (line 142)
Error in new_rfda (line 561)
Error in run_extool (line 279)
Error in ex_tool2>run_case_Callback (line 1029)
Error in gui_mainfcn (line 96)
Error in ex_tool2 (line 42)
Error in @(hObject,eventdata)ex_tool2('run_case_Callback',hObject,eventdata,guidata(hObject))
Error while evaluating uicontrol Callback
Kindly provide your suggestion / feedback to resolve above mentioned errors.
CarlosAM_INTEL
Hello, @KMANO3​:
Could you please confirm that you are following the suggestions stated in section 5.3.1, on pages 31, 32, and 33 of the Broadwell-DE Processor DDR4 Signal Integrity Model User Guide (MUG) document # 545924 and in Intel(R) Memory Bit Error Rate Executable [Intel(R) MBERE] User’s Guide document # 569813? These document can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/545924.htm
http://www.intel.com/cd/edesign/library/asmo-na/eng/569813.htm
The RDC Account Support form is the channel to report or solve any inconvenience related to the cited site, also process your RDC account upgrade. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
Could you please verify if the problem persists with any MATLAB* Compiler Runtime (MCR) version different than the one that you have mentioned? The different versions can be found as a reference at the following website:
https://www.mathworks.com/products/compiler/matlab-runtime.html
We are waiting for your answer.
@Mæcenas_INTEL​.
KMANO3
We have followed the same procedure as mentioned in the document  # 545924 ( Broadwell-DE Processor DDR4 Signal Integrity Model User Guide (MUG) ) and # 569813 (Intel(R) Memory Bit Error Rate Executable [Intel(R) MBERE]).
We are struck with this issue, requesting to provide your feedback/suggestion at the earliest to resolve the error.
CarlosAM_INTEL
Hello, @KMANO3​:
Thanks for your update.
Could you please let us know the results of the suggestion stated on the last question of our previous communication?
We are waiting for your reply.
@Mæcenas_INTEL​.
KMANO3
We are using same MATLAB* Compiler Runtime (MCR) version 8.0 (R2012b) as mentioned.
When you see the log file, error seems to be in reading the tr0 file.
For your Information even we have tried with HSPICE 2013 version for the tr0 generation, with this also we are observing same errors.
If possible shall we have WebEx session to discuss the issue and resolve at the earliest.
CarlosAM_INTEL
Hello, @KMANO3​:
Thanks for your reply.
We have contacted you via email.
@Mæcenas_INTEL​.
RChia12
Hello @Mæcenas_INTEL​ ,
We try to refer your suggestions, but also observing the same MBERE error as KMANO3.
How can I do now?
thanks
CarlosAM_INTEL
Hello, @RChia12​:
Could you please clarify if this situation happens on your design or a third- party design?
In case that it is a third-party device, could you please inform the name of the manufacturer, its model, the part number, and where its documentation is stated?
On the other hand, could you please let us know how many units of the project related to this circumstance have been manufactured? How many are affected? Could you please give the failure rate? Also, could you please list the sources that you have used to design it and if it has been verified by Intel? Could you please let us the procedure that you have followed to determine this issue?
Could you please give party number or pictures of the top side markings of the affected processors?
We are waiting for your reply to these questions.
@Mæcenas_INTEL​.
RChia12
Hello @[Mæcenas_INTEL]​,
In fact, we use intel example deck to simulate by MBERE first.
After verifying the deck is no problem, we would use our design to do the same step.
We download 545924-bdw-de-ddr4-si-model-rev0p95zip and follow the user guide to generate intel example deck(.sp)
When we use dq_wr or dq_rd example deck of SODIMM to run Hspice and generate tr0, it can simulate successfully by MBERE
But when we use Hspice to simulation cmd_ctl example deck of SODIMM and generate tr0 and then put it to MBERE, it will show error message from MBERE window.
The example deck was from BDW_DE_DDR4_SI_Model_Rev0p95\SODIMM\cmd_ctl\cmd_near_9p2mm_9p2mm\cmd_near_sodimm_92_92_corner_1.sp
CarlosAM_INTEL
Hello, @RChia12​:
We have sent an email to help you.
@Mæcenas_INTEL​.
