Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
309 Discussions
camelback mountain CRB board booting issue.
KMANO3
we are currently working with Camelback mountain CRB, the jumper J6J5 in the CRB peeled out while swapping the jumpers, we temporarily fixed by soldering the necessary pins, but still the Board is not BOOTING up.
Please let us know how to proceed further. We tried probing the CS pin of out of the SOC, there are no signals observed. debugging further showed the that Core rail 1.8V it self is not powered up. Is it some error in the CPLD in power sequencing or any other issue. Please let us know how to proceed further.
CarlosAM_INTEL
Hello, @KMANO3​:
Could you please confirm that you are following all the guidelines stated in the Camelback Mountain Costumer Reference Board (CRB) User Guide (Broadwell-DE SoC) document # 554715? This document can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/554715.htm
The RDC Account Support form is the channel to process your account update request or any inconvenience related to the provided website. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
We are waiting for your answer.
@Mæcenas_INTEL​.
KMANO3
YES , we followed all the instructions, it was working properly until few days back when it stopped booting up. only problem we saw was the Jumper J6J5 connectivity which we soldered connecting the necessary connections as per the schematic. Please advice how to boot back the board. is there any CPLD code for the CRB available? which we can try to flash.
CarlosAM_INTEL
Hello, @KMANO3​:
Thanks for your reply.
Based on the provided information, could you please let us know the procedure that you have obtained the CRB?
We are waiting for your clarification.
@Mæcenas_INTEL​.
KMANO3
we got it from our end customer which they received from intel, Israel local SPOC Ofer.
CarlosAM_INTEL
Hello, @KMANO3​:
Thanks for your clarification.
We have contacted you via to provide suggestions that may help you.
@Mæcenas_INTEL​.
