Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
315 Discussions
Disabling TCC and Data Stream Optimizer in BIOS
victor20
I am running a Xeon W-11155MLE processor for a real-time application, so low latency is important requirement. However, I also require the processor to be in Turbo Mode with SpeedStep enabled for a steady CPU clock frequency.
I have found that TCC and Data Streams Optimizer in the BIOS interferes with the ability to enable SpeedStep. So I am looking to understand the implications of disabling TCC and Data Streams Optimizer. Ideally both settings would be enabled for low latency and steady CPU frequency.
Any way to get the best of both worlds?
NormanS_Intel
Hello victor20,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Embedded Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
Diego_INTEL
Hello @victor20,
Regarding TCC in Tiger Lake, that is correct, it is not possible to have TCC and SpeedStep enabled.
Unfortunately TCC must be disabled to keep SpeedStep enabled, also, as I know, if SpeedStep is disabled, it may affect if you want to configure a scaling frequency too.
@Diego_INTEL
