Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
317 Discussions
Ethernet 10G Simulation Models
KMANO3
Hello Team,
We couldnt able to find the Ethernet 10G Simulation models for Xeon D1559. Kindly share the model or provide any equivalent model for the same Xeon D1559.
Thanks in Advance.
CarlosAM_INTEL
Hello, @KMANO3​:
Could you please clarify if this request is related to any problem with an implementation of the cited processor? In case your answer is affirmative, please give a detailed description of the issue.
We are waiting for your clarification.
@Mæcenas_INTEL​.
KMANO3
We need to perform SI simulation for Ethernet 10G interface in D1559 processor. But there is no model (IBIS, SPICE) for that. We are looking on the same processor model or any equivalent processor model. Kindly suggest the model information availability.
Thanks in Advance,
CarlosAM_INTEL
Hello, @KMANO3​:
Thanks for your reply.
We suggest you use the Broadwell-DE [BDX-DE V2 and Y0 Stepping] 10G LAN Enabling Kit [LEK] document # 561475 . It is is accessible to you when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/561475.htm
The RDC Account Support form is the channel to process your account update request. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
@Mæcenas_INTEL​.
