Ethernet Products
5762 Discussions
25G x 4 retimer + rsfec
AbhijitKhadilkar
Hello, If the SOC does not support RSfec. Can the device C827-AM1 be used between SOC 25G KR port and SFP+ (25Gbps optics) to encode and decode RS-FEC?
How do i access the datasheet and order evaluation board for this device ?
Thanks, Abhijit
Amina_Sadiya
Hello AbhijitKhadilkar,
Greetings from Intel!
Thank you for contacting Intel. To proceed further with your query, I kindly request that you share the below details:
1. Product details
2. Please share the system details in which the product is installed.
Amina
AbhijitKhadilkar
  1. Product details --- GnodeB hardware
  2. This Intel Phy will be used to connect the baseband SOC eth port to 25G SFP+.
thanks, Abhijit
TejasMohan
Hello AbhijitKhadilkar ,
Thank you for getting back to us and confirming the details.
Regarding the product C827-AM1, you can refer to the following link for detailed specifications:
https://www.intel.com/content/www/us/en/products/sku/128969/intel-ethernet-connection-c827am1/specifications.html
As for the datasheet, please note that it is an Intel confidential document and requires an active Corporate Non-Disclosure Agreement (CNDA) with Intel to access.
If you have a valid CNDA, you can request access to the Resource and Documentation Center (RDC) using the article below:
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html?wapkw=000058073
Once you have RDC access, you can search for the datasheet using Article ID: 571632 at the following link:
https://www.intel.com/content/www/us/en/resources-documentation/developer.html
Tejas
AbhijitKhadilkar
Hi Experts,
If the SOC does not support RSfec. Can the device C827-AM1 be used between SOC 25G KR port and SFP+ (25Gbps optics) to encode and decode RS-FEC? Thanks, Abhijit
Fikri_Intel
Hi AbhijitKhadilkar,
Thank you for your response.
We highly recommend to refer the datasheet. Please note that the document is not publicly available. You can get the datasheets from Intel RDC site below but the document will requires CNDA:
For further details, you can refer to the below link on how to register as a Developer Zone Premier account and sign the CNDA:
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentat…
Additionally, I've attached the datasheet link as well. Please login before you can access the file.
File Name: 571632-parkvale-ds-571632-rev-1-2.pdf
Content ID: 571632
URL Link: https://www.intel.com/content/www/us/en/secure/design/internal/content-details.html?DocID=571632
Fikri O.
Amina_Sadiya
This is a reminder regarding the issue you reported to us.
We are eager to ensure a swift resolution and would greatly appreciate an updates if you had a chance to look into the information we have shared previously and provide us an update on the same.
Amina
Amina_Sadiya
Greetings from Intel.
This is the final follow-up regarding the reported issue. As we have not heard back from you, we'll assume the issue has been resolved and will proceed to close the case.
Amina
