Ethernet Products
4919 Discussions
40Gb Ethernet HSSI MAC/PHY IP does not work on Arria-10
SXian3
I am trying to run the 40Gb Ethernet MAC/PHY IP provided by the OPAE. I am using the fpga-pac-a10 severs. Two problems I have here:
1. When testing the pre-built GBS from the example design with `hssi_loopback` utility, it complains that it cannot initialize the AFU.
$ hssi_loopback readmacs -B 0xAF Found e40 Error initializing accelerator
2. I also developed a simple AFU using `eth_e2e_e40` module provided in the example design. When running the example on Arria-10, the start signal of this module was set high, but the module never receives any non-zero PrMgmtCmd from the HSSI interface, and the `init_done` signal is always low (i.e. it is never initialized properly).
The PrMgmtCmd should have been configured correctly by writing the corresponding CSRs in the software using the `fpgaHssiSendPacket` API. What is the problem here?
Also, I am wondering if the fpga-bdx-opae platform can support the HSSI networking feature? It seems that this integrated FPGA-CPU platform should have support for HSSI: https://opae.github.io/latest/docs/fpga_tools/hssi_config/readme.html. But I go another another error when compiling the program (if I use the hssi interface in the AFU top-level module)
Error: ccip_std_afu needs port hssi:raw_pr that a10_gx_intg_xeon_bdx doesn't offer Error: "afu_platform_config --qsf --tgt platform --src=../../hw/rtl/eth_e2e_e40.json a10_gx_intg_xeon_bdx" failed
Caguicla_Intel
Hello SXian3,
Since your query is related to FPGA product, we suggest posting your query on the forum link below for further assistance.
Go to 'Featured Topic' > 'FPGA Developers' then, post question on the appropriate subforum topic.
Intel Community forums
https://forums.intel.com/s/
Let us know if you have additional questions and clarifications.
Please be advised that we will proceed with request closure. Just feel free to post a new question if you may have any other inquiry in the future.
May you have an amazing day ahead!
Crisselle C
Intel® Customer Support
