- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Yesterday i installed Windows 10 pro, (1903, the newest) in an Lenovo m92z (that has Intel 82579LM Ethernet Controller). Before, the PC run Windows 8.1 pro and had multiple vlan`s on the nic.
I tested various prowin64.exe drivers (at the moment, i have 22.10.3.0), but i cannot get vlan`s eorking. When i create a new vlan, it is established, but remains disabled. When i try to enable it, a popup with "enabling" is shown, but it stays disabled.
With win 8.1 , i had nio problems. What is the problem? what is wrong? what drivers should be used to get this working?
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello FBode2,
Thank you for posting in Intel Ethernet Communities. Please be informed that this is a known issue on Windows 10 (1903). Kindly check the information below:
Support for Microsoft Windows* 10, Version 1903 (19H1) & Microsoft* Windows Server* 2019, Version 1903 (19H1) will be available in SW Release 24.1.
SW Release 24.1 will support Microsoft Windows* 10, Version 1903 & Microsoft* Windows Server* 2019, Version 1903 and also include fixes for issues some customers were experiencing with Team and VLAN configuration using PowerShell.
SW Release 24.1 is expected in June of 2019.
Important Note: Prior to the release of SW 24.1, we will be releasing SW 24.0. Please be aware that 24.0 does not support Microsoft Windows* 10, Version 1903 or Microsoft* Windows Server* 2019, Version 1903. Support for Microsoft Windows* 10, Version 1903 & Microsoft* Windows Server* 2019, Version 1903 will be in release 24.1
The Intel Ethernet team is responsible for validating and submitting new driver packages to Microsoft for inclusion on Windows Update. Microsoft does not support Team and VLAN configuration on Window 10. Team and VLAN configuration for Intel Ethernet Adapters on Windows 10 is supported via our Intel® PROSet software. Intel® PROSet is not included on Microsoft Windows Update.
For the meantime, you may also try to fresh install Windows 10 (1809) as this was also encountered by another customer.
https://forums.intel.com/s/question/0D50P00004LVFNh/vlan-support-broken-windows-10-1903-prowinx64v2352-on-i219lm
Let us know if you have additional questions.
Crisselle C
Intel Customer Support
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello FBode2,
We'd like to check if we were able to address your query. If you have additional questions and clarifications, please do not hesitate to contact us.
Crisselle C
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello FBode2,
Please let us know if you have any other concerns or assistance needed on this matter, feel free to post on this thread and we will be glad to be of help.
Crisselle C
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi FBode2,
Please be informed the SW 24.1 is already available in Download Center, for additional details, kindly check out this thread.
Let us know if it fixes your VLAN issue.
Vince T.
A Contingent Worker at Intel
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Version 24.1 on Windows 10 v1809 still does not allow multiple VLANs to be created/active on an Intel l219-LM network device!
No VLAN settings available in the IntelPRO Set Adapter Configuration Utility.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello RNiel1,
Is there any error that you encountered while creating multiple VLANs? Have you tried to uninstall then reinstall the driver?
As mentioned on this thread, Team and VLAN configuration are only supported using Intel® PROSet for Windows PowerShell* Software's cmdlets. This only applies to Microsoft Windows* 10. And we plan to add Advanced Network Services including Team and VLAN configuration to the Intel® PROSet Adapter Configuration Utility interface in a future release.
Crisselle C.
