After a day and a half of troubleshooting why my NIC was showing down in VMware ESXi 6 even though it had green lights on both ends of the fiber and my Cisco 8500 switch said the circuit was up-up, I finally found the answer.
Gee, the Cisco SFP-10G-LRM SFP+ module I use throughout my network isn't compatible in the Intel NIC. Apparently I need an Intel E10GSFPLR SFP+ module in the NIC.
Of course this should work with the SFP-10G-LRM on one end and the E10GSFPLR on the other end, but can anyone verify this?
Hi LSS_Engineer,
Yes, the Intel Adapter is compatible with Intel SFP+ modules. With regards to your question, the E10GSFPLR module supports standard 10GBASE-LR 10G Ethernet. If your Cisco* switch can support 10GBASE-LR standard, then it is compatible. However, you may need to use Cisco's 10GBASE-LR module for your switch.
Hope this helps.
Sincerely,
Sandy
Hi LSS_Engineer,
Hope this helps.
Sincerely,
Sandy
Thanks Sandy,
They way I now understand this is that I have two choices:
1. Replace my Cisco SFP-10G-LRM modules with SFP-10G-LR modules on the switch and install an Intel E10GSFPLR module in the Intel NIC. This requires changing the MM OM3 fiber to standard SM.
2. Replace my Cisco SFP-10G-LRM modules with SFP-10G-SR modules and install and Intel E10GSFPSR module in the Intel NIC and retain the existing MM OM3 fiber.
We can solve this problem, please click this URL:https://www.fibermall.com/sale-420143-intel-e10gsfplr-compatible-10g-sfp%2b-lr-1310nm-10km-lc-smf-ddm-transceiver-module.htm?iso=us![SFP-10G31-LR (1).jpg SFP-10G31-LR (1).jpg](https://community.intel.com/t5/image/serverpage/image-id/10908iF8ADDD7994F80671/image-size/large/is-moderation-mode/true?v=v2&px=999&whitelist-exif-data=Orientation%2CResolution%2COriginalDefaultFinalSize%2CCopyright)
![](/skins/images/DCC883141309A464C31AD18F1D8B9C6A/responsive_peak/images/icon_anonymous_message.png)
