Ethernet Products
5690 Discussions
ARP not working for Virtual Functions created over XL710 port
Acdam
Hi Experts,
I have created 2 virtual functions over a PF using below commands:
echo 2 > /sys/class/net/p7p1/device/sriov_numvfs
After running this command, it created 2 VFs, which are now visible in ifconfig command output as p7p1_0 and p7p1_1
I have assigned 2 IPs of same subnet to both the VFs, lets say:
p7p1_0 => 192.168.1.5 and MAC address 11:22:33:44:55:66
p7p1_1 => 192.168.1.6 and MAC address 12:23:34:45:56:67
This physical port is connected via back to back connection to p7p1 of another server which is having ip address 192.168.1.7 on connected physical port.
Server-1 (PF p7p1 : 192.168.1.7)  <======> Server-2(VF0 p7p1_0 : 192.168.1.5 and VF1 p7p1_1 :192.168.1.6)
Now, when I ping 192.168.1.5 and 192.168.1.6 from Server-1 via interface (192.168.1.7), then below are the ARP entries at Server-1
ARP entries on Server-1 :
? (192.168.1.5) at 11:22:33:44:55:66 [ether] on p7p1
? (192.168.1.6) at 11:22:33:44:55:66 [ether] on p7p1
Which means that VF 0 responded to ARP request for both the VFs (VF0 and VF1).
Driver versions:
[root@server]# modinfo i40e | grep version
version: 2.12.6
[root@server]# modinfo iavf | grep version
version: 4.4.2
Can someone please help on what's going wrong in above setup for ARP resolution ?
Actual Issue caused by above wrong ARP entries:
I want to run 2 DPDK based applications on created VFs (App1 on VF0 and App2 on VF1) on Server-2 and Server-1 will pump data equally for both VFs/Applications.
As Server-1 is having MAC address of VF0 for both the ARP entries corresponding to VF0 and VF1, so all the data packets pumped by Server-1 (destination to VF0 and VF1) are getting received at only VF0 (App-1) be its destination is VF0 or VF1.
Zigfreid_Intel
Hello Acdam,
Since this question involves DPDK, please check with Intel Premier Support for further assistance. See the following for access to Intel Premier Support.
Click the "Access and Log In" to contact the DPDK support
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Please be informed that we will now close this request. Just feel free to post a new question if you have any other inquiry in the future as this thread will no longer be monitored.
Zigfreid I.
Intel® Customer Support
Acdam
Hi @Zigfreid_Intel ,
Thanks for responding on this thread.
As I have explained in the original post that issue is at ARP resolution of interfaces over VFs and to rule out the DPDK and coding stuff, I have recreated this issue with just Pings over VFs (explained in original post).
Please refer to attached image as well for the same.
Would be of great help if you can please explain on why only 1 VF responds to ARP request for all VF interfaces ?
