Ethernet Products
4633 Discussions
Allocating multiple VLANs to a single VF using SR-IOV NIC card
SBhat29
Is there a way to allocate multiple VLANs to a single VF using SR-IOV NIC card ? How VLAN tagged packets can be forwarded by the KVM Hypervisor received via SR-IOV device from Physical Port towards the VM on DPDK driver interface ? Which DPDK driver to use igb_uio or vfio-pci? Also which DPDK 18.08 RTE API's can be used to read what VLAN id is set on the Host VF, from the guest?
