Ethernet Products
5672 Discussions
Bootutil Tools under Linux
SteveFP
Hello all,
I am trying to get the Bootutil tool to run under Debian 11. I have ensured that the latest GCC is installed on the system. I created the temp directory and moved over Install and the tar file. When I run ./install it throws up the following error:
Compiling the driver...Error: ./install: line 80: make: command not found
Error: unable to find driver file (iqvlinux.ko) in /root/temp/iqvlinux/src/linux/driver
When I look at the directory under driver I see no iqvlinux.ko file, as in the attached directory screenshot. Why is this and where do I find this missing file?
Steve
