我无法将固件升级到版本 2.46 E810-CQDA2 网络适配器。
从以下位置下载的固件包:
用于英特尔®以太网网络适配器 E810 系列的非易失性内存 (NVM) 更新实用程序 — Linux*
我当前的驱动程序和固件版本是:
root@lxm:~/E810/EFI2x64# ethtool -i enp131s0f0
driver: ice
version: 1.15.4
firmware-version: 2.30 0x80005d09 1.2877.0
expansion-rom-version:
bus-info: 0000:83:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
NIC lspci 信息:
root@lxm:~/E810/EFI2x64# cat /sys/bus/pci/devices/0000\:83\:00.0/vpd
)Intel(R) Ethernet Controller E810-CAM1/2/V0(Intel(R) Ethernet Controller E810-CAM1/2RVx
当我尝试将固件更新到版本 2.46 时,我收到以下错误消息:
root@lxm:~/E810/Linux_x64# ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.42.8.0
Copyright(C) 2013 - 2024 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) I350 Gigabit Network N/A(N/A) 1521 00:001 Update not
Connection available
02) Intel(R) Ethernet Controller N/A(N/A) 1592 00:131 Update not
E810-C for QSFP available
Tool execution completed with the following status: Device not found.
Press any key to exit.
root@lxm:~/E810/Linux_x64# ./nvmupdate64e -u -l -o update.xml -b -c nvmupdate.cfg
Config file read.
No devices to update.
Post update inventory
导出 QV_DEBUG_LOG=0xFFFFFFFF
导出 NUL_DEBUGLOG=1
./nvmupdate64e -l -c nvmupdate.cfg
我上传 : nvmupdate.log
我尝试修复 nvmupdate.cfg:
这是 NetCard 映像:
BEGIN DEVICE
DEVICENAME: E810_QSFP_100G_NRB_INV
VENDOR: 8086
DEVICE: 1592
SUBVENDOR: 8086
SUBDEVICE: 0000
NVM IMAGE: E810_QSFP_100G_NRB_INV_SEC_FW_*.bin
EEPID: 80005D09
SKIP NETLIST: FALSE
IMAGE DOWNGRADE: TRUE
RESET TYPE: REBOOT
REVISION: 1 ; I changed the value here from 02 to 1 and successfully updated. How will this affect my network card?
END DEVICE
