Ethernet Products
5657 Discussions
Configuring XL710 on Centos 7
JMcDo8
I am trying to configure a XL710 interface card on Centos 7 with two 10G ports. The host is a DELL R610.
I have installed the latest drivers and up graded the firmware.
The network card does not come live - I have it connected to another R610 with IXGBE interfaces through a optical/copper interface - which shows that the optical interfaces of the XL710 are not live.
When I try yo use QCU to configure the interface it does not recognize the interface, but when I run nvmcheck4e it recognizes the interfaces.
Is my problem that I cannot set the configuration through QCU or is it something else?
John
My setup is as follows
[root@localhost Linux_x64]# uname -r
3.10.0-229.11.1.el7.x86_64
[root@localhost Linux_x64]# ethtool -i p1p1
driver: i40e
version: 1.3.38
firmware-version: 4.53 0x80001dc0 0.0.0
bus-info: 0000:04:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
[root@localhost Linux_x64]# ./qcu64e
Intel(R) QSFP+ Configuration Utility
QCU version: v1.24.35.01
Copyright(C) 2015 by Intel Corporation.
Software released under Intel Proprietary License.
NIC B:D Ven-Dev Mode Adapter Name
No supported adapters detected.
[root@localhost Linux_x64]# ./nvmcheck64e
NVM Integrity Verification Tool v1.25.01.03
Using: Intel (R) PRO Network Connections SDK v2.25.1
Copyright (C) 2012 - 2015 by Intel (R) Corporation.
Software released under Intel(R) Corporation Propietary License.
Usage:
/HELP Displays supported commands with description.
/? Displays supported commands with description.
/VERSION Displays tool and QV SDK version.
/DEVICES Shows available adapters.
/NIC=X Selects a specific adapter (1-32).
/VERIFY Verify NVM Signature of selected card.
Technical support options:
/HEADER Show NVM header of selected card.
/KEY Show NVM key of selected card.
[root@localhost Linux_x64]# ./nvmcheck64e -devices
NIC B/D/F Ven-Dev MAC ENA Branding string
1) 04/00/00 8086-1572 6805CA305270 YES Intel(R) Ethernet Converged Network Ada
2) 04/00/01 8086-1572 ------------ N/A ------------
3) 08/00/00 8086-10BC 001B21B69F21 N/A Intel(R) PRO/1000 PT Quad Port LP Serve
4) 08/00/01 8086-10BC 001B21B69F20 N/A Intel(R) PRO/1000 PT Quad...
st4
New Contributor III
Hi Doonhammer,
Thank you for the post. Can you provide the serial number of the XL710 network adapter model? The serial number comes with the format of
15 alphanumerics + 6 alphanumerics + 6 alphanumerics -3 digits
Please feel free to update us.
rgds,
wb
JMcDo8
wb,
Thanks for the reply - from the driver support forum we figured out the problem is that we are not using Intel Optics. I have just ordered some and will try that.
John
st4
New Contributor III
Hi Doonhammer,
Thank you for the update. It is recommended to use Intel optics and hope this will fix the issue.
rgds,
wb
