Ethernet Products
5769 Discussions
Creating software bridge with SR-IOV PF NIC
MRaja5
Test 1:
We are trying to create a software bridge as mentioned below on SR-IOV enabled 40 gig PF NIC. Then We tried to create VM on the two vnet interface. The issue is whenever VM is sending some broadcast packet, it receiving it back by itself.
[root@hyp-1 ~]# brctl show brosf
bridge name bridge id STP enabled interfaces
brosf 8000.6805ca2d50c0 no ens3f0
vnet4
vnet7
# brctl showmacs brosf
port no mac addr is local? ageing timer
1 68:05:ca:2d:50:c0 yes 0.00
1 fa:ac:a4:00:f8:03 no 0.10
1 fa:ac:a4:00:f9:03 no 0.09
1 fa:ac:a4:01:f1:03 no 0.04
1 fa:ac:a4:02:73:03 no 0.03
2 fe:ac:a4:00:f8:03 yes 0.00
3 fe:ac:a4:00:f9:03 yes 0.00
where
Port 1 is ens3f0 (PF)
port 2 is vnet4
port 3 is vnet7
# ip link show ens3f0
7: ens3f0: mtu 9000 qdisc mq master brosf state UP mode DEFAULT qlen 1000
link/ether 68:05:ca:2d:50:c0 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
vf 1 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
Test 2:
We tried same thing by disabling the num of vf on the same 40 gig NIC. It is working fine. The details are as below:
[root@hyp-3 0000:04:00.0]# brctl show brosf
brosf 8000.6805ca2e7f00 no ens3
vnet2
vnet5
[root@hyp-3 0000:04:00.0]# brctl showmacs brosf
1 68:05:ca:2e:7f:00 yes 0.00
1 fa:ac:a4:00:f8:03 no 0.11
1 fa:ac:a4:00:f9:03 no 0.00
2 fa:ac:a4:01:f1:03 no 0.07
3 fa:ac:a4:02:73:03 no 0.04
2 fe:ac:a4:01:f1:03 yes 0.00
3 fe:ac:a4:02:73:03 yes 0.00
[root@hyp-3 0000:04:00.0]# ip link show ens3
31: ens3: mtu 1500 qdisc mq master brosf state UP mode DEFAULT qlen 1000
link/ether 68:05:ca:2e:7f:00 brd ff:ff:ff:ff:ff:ff
Details:
Host Os
Centos 7
PF:
04:00.0 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 01)
# modinfo i40e
filename: /lib/modules/3.10.0-123.9.3.el7.x86_64/kernel/drivers/net/ethernet/intel/i40e/i40e.ko
version: 1.0.15
license: GPL
description: Intel(R) Ethernet Connection XL710 Network Driver
vermagic: 3.10.0-123.9.3.el7.x86_64 SMP mod_unload modversions
Observation
In both scenario, there is difference in population mac address.
Query
I gone through some article, they mentioned if SR IOV is enabled, Physical Function (PF) does not work in bridge mode. May i know the reason for this?
May i know the reason, why with vf is enabled, the broadcast packets are received by VM itself.
SYeo3
Valued Contributor I
Hi Meganathan,
Thank you for contacting Intel. I'll check on this and will update you once I find anything.
Sincerely,
Sandy
MRaja5
Hi Sandy,
Please let me know if you have any update on this issue?
Meganathan
SYeo3
Hi Meganathan,
Thanks for your post.
Please update to the latest driver and refer to the programmer's guide below:
1. Network Adapter Driver for PCI-E 40 Gigabit Network Connections under Linux*
File name: i40e-1.2.48.tar.gz
Version: 1.2.48 (Latest)
https://downloadcenter.intel.com/download/24411 https://downloadcenter.intel.com/download/24411
2. Intel® Data Plane Development Kit (Intel® DPDK) Programmer's Guide
http://dpdk.org/doc/intel/dpdk-prog-guide-1.7.0.pdf http://dpdk.org/doc/intel/dpdk-prog-guide-1.7.0.pdf
Section 12 discusses about Virtio vs SRIOV implementation.
3. Try this procedure in assigning PF to Bridge:
1. Reboot the server
2. Assign PF to the bridge
3. Once PF is assigned to the bridge, ping the host on the network.
4. Provide dmesg log.
Hope this helps.
Sincerely,
Sandy
