Ethernet Products
5654 Обсуждение
Configuring XL710 on Centos 7
JMcDo8
Начинающий
4 936Просмотр.
I am trying to configure a XL710 interface card on Centos 7 with two 10G ports. The host is a DELL R610.
I have installed the latest drivers and up graded the firmware.
The network card does not come live - I have it connected to another R610 with IXGBE interfaces through a optical/copper interface - which shows that the optical interfaces of the XL710 are not live.
When I try yo use QCU to configure the interface it does not recognize the interface, but when I run nvmcheck4e it recognizes the interfaces.
Is my problem that I cannot set the configuration through QCU or is it something else?
John
My setup is as follows
[root@localhost Linux_x64]# uname -r
3.10.0-229.11.1.el7.x86_64
[root@localhost Linux_x64]# ethtool -i p1p1
driver: i40e
version: 1.3.38
firmware-version: 4.53 0x80001dc0 0.0.0
bus-info: 0000:04:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
[root@localhost Linux_x64]# ./qcu64e
Intel(R) QSFP+ Configuration Utility
QCU version: v1.24.35.01
Copyright(C) 2015 by Intel Corporation.
Software released under Intel Proprietary License.
NIC B:D Ven-Dev Mode Adapter Name
No supported adapters detected.
[root@localhost Linux_x64]# ./nvmcheck64e
NVM Integrity Verification Tool v1.25.01.03
Using: Intel (R) PRO Network Connections SDK v2.25.1
Copyright (C) 2012 - 2015 by Intel (R) Corporation.
Software released under Intel(R) Corporation Propietary License.
Usage:
/HELP Displays supported commands with description.
/? Displays supported commands with description.
/VERSION Displays tool and QV SDK version.
/DEVICES Shows available adapters.
/NIC=X Selects a specific adapter (1-32).
/VERIFY Verify NVM Signature of selected card.
Technical support options:
/HEADER Show NVM header of selected card.
/KEY Show NVM key of selected card.
[root@localhost Linux_x64]# ./nvmcheck64e -devices
NIC B/D/F Ven-Dev MAC ENA Branding string
1) 04/00/00 8086-1572 6805CA305270 YES Intel(R) Ethernet Converged Network Ada
2) 04/00/01 8086-1572 ------------ N/A ------------
3) 08/00/00 8086-10BC 001B21B69F21 N/A Intel(R) PRO/1000 PT Quad Port LP Serve
4) 08/00/01 8086-10BC 001B21B69F20 N/A Intel(R) PRO/1000 PT Quad...
0 баллов
3 Ответы
st4
Новый участник III
3 161Просмотр.
Hi Doonhammer,
Thank you for the post. Can you provide the serial number of the XL710 network adapter model? The serial number comes with the format of
15 alphanumerics + 6 alphanumerics + 6 alphanumerics -3 digits
Please feel free to update us.
rgds,
wb
JMcDo8
Начинающий
3 161Просмотр.
wb,
Thanks for the reply - from the driver support forum we figured out the problem is that we are not using Intel Optics. I have just ordered some and will try that.
John
st4
Новый участник III
3 161Просмотр.
Hi Doonhammer,
Thank you for the update. It is recommended to use Intel optics and hope this will fix the issue.
rgds,
wb
Ответить
