Ethernet Products
4974 Discussions
DZ87KLT 75K
Jetrell
I have an Intel DZ87KLT 75K motherboard and I am running Windows 7 64-bit. I'm looking for Ethernet drivers for my board but I can't find them. Can someone here please show me a direct link? Thanks in advance.
AlHill
You are welcome.   But, the truth is I happen to have a few of those boards, and kept the drivers.
If you decide to go to Windows 10, you will not have any trouble.   And, W10 works very well on this board.
AlHill
This should do it.
https://www.intel.com/content/www/us/en/download/15590/intel-network-adapter-driver-for-windows-7-final-release.html?
Jetrell
Thank you so very much! I was looking and looking but I couldn't do what you did and you did it so very fast. Thank you again, you are indeed a Super User!
Kudos,
AlHill
Thanks, but let's make sure it works first.
Jetrell
What do you mean, it totally works! It was easy and simple, thanks to you! I'm online and very happy!
Unfortunately I have another situation... In "Device Manager" under "Other Devices" there are 3 things with exclamation points.
1. PCI Simple Communications Controller
2. SM Bus Controller
3. Universal Serial Bus (USB) Controller
Are there drivers for these 3 problems as well?
AlHill
Install the chipset INF.
Then install the management engine
Then install the USB driver.
Jetrell
Hi there,
I have a dumb question, but I just want to make sure I understand the correct order of the installs.
1. "INF_allOS" = chipset INF?
2. "MEI_Win8.1" = management engine?
3. "Intel(R)_USB" = USB driver?
Is that the correct order?
Thanks again!
AlHill
Yes, that should do it.
Jetrell
It's working! Everything is working! Thank you for the link, the downloads, and thank you for your time, patience, and understanding! I am so very thankful! Have a great day!
AlHill
Jetrell
That's great to know, I will probably be upgrading to Windows 10 shortly.
Thank you again!
