Dear Support professionals,
Denverton Ethernet IXGBE spoof check for VF not working with IXGBE 5.14.6 version.
This is the context:
We have IXGBE 5.14.6 version (and this is also observed in an older version)
Kindly requesting to treat this as highest priority since this is blocking very critical deployment please. Much appreciate your kind important attention and valuable guidance please
The following are the steps:
These steps will indicate that
spoof check off functionality is not working in Denverton
Can we please request you to give the root cause as why spoof check off is not working.
STEPS done please:
1) rmmod ixgbe
2) modprobe ixgbe MDD=0,0,0,0
3) echo command to create VF
4) Ip link command to Trust on
5) Ip link command to spoof check off
6) Create a condition for Spoof - by sending a packet with SRC address = DST address
7) Since Spoof check was off (in step 5), we should not see spoof check and the packet should TX
9) And TX does not happen as well.
10) This indicates that the spoof check off functionality is not working in Denverton
11) Can we please request you to give the root cause as why spoof check off is not working.
Hello Muthurajan_J_Intel,
Can you share the exact model of your system and Ethernet adapter you used.
If you are using an Intel server system, please share the product code and SN of your system. You may refer on the link below on Where to Find the Product Code and Serial Number for Intel® Data Center Systems (Intel® DCS)
Hoping to hear from you soon.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Dear customer support,
Thank you so much for your valuable reply.
Kindly find the output of cat /proc/cpuinfo that has model info below please
It is Intel Atom CPU C3436L and Model is 95.
Full detail below.
After the full details, kindly find also the information about the integrated NIC - which is what our focus is Intel Corporation Ethernet Connection X553 Backplane
Thank you very much,
Info below please
processor : 3
vendor_id : GenuineIntel
cpu family : 6
model : 95
model name : Intel(R) Atom(TM) CPU C3436L @ 1.30GHz
stepping : 1
microcode : 0x38
cpu MHz : 1300.000
cache size : 2048 KB
physical id : 0
siblings : 4
core id : 12
cpu cores : 4
apicid : 24
initial apicid : 24
fpu : yes
fpu_exception : yes
cpuid level : 21
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm 3dnowprefetch cpuid_fault epb cat_l2 ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust smep erms mpx rdt_a rdseed smap clflushopt intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves dtherm arat pln pts md_clear arch_capabilities
vmx flags : vnmi preemption_timer posted_intr invvpid ept_x_only ept_ad ept_1gb flexpriority apicv tsc_offset vtpr mtf vapic ept vpid unrestricted_guest vapic_reg vid ple shadow_vmcs
INTEGRATED NIC:
root@user-JACOBSVILLE-SNR-NS:/home/user# lspci -v -s 07:00.0
07:00.0 Ethernet controller: Intel Corporation Ethernet Connection X553 Backplane (rev 11)
Subsystem: Intel Corporation Ethernet Connection X553 Backplane
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at 84c00000 (64-bit, prefetchable) [size=2M]
Memory at 84e04000 (64-bit, prefetchable) [size=16K]
Expansion ROM at 84e80000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=64 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 00-00-c9-ff-ff-00-00-00
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1b0] Access Control Services
Kernel driver in use: ixgbe
Thank you for sharing the information of your CPU and Ethernet however, we need the model of the system you use.
Will you be able to confirm if you are using an Intel server system? If yes, please share the product code and SN of your system. You may refer on the link below on Where to Find the Product Code and Serial Number for Intel® Data Center Systems (Intel® DCS)
Awaiting to your reply.
Should there be no response from you, I’ll make sure to reach out after 3 business days.
Crisselle C.
Good day!
This is just a follow up confirm if you are using an Intel server system? If yes, please share the product code and SN of your system. You may refer on the link below on Where to Find the Product Code and Serial Number for Intel® Data Center Systems (Intel® DCS)
Crisselle C.
I hope this message finds you well!
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
May you have a good day and stay safe!
Crisselle C.
