Ethernet Products
5821 Discussions
Does the I340-F4 support 100base-FX SFP modules
CGill4
We am looking for a quad port PCI express card with 100base-FX interfaces, under Windows 7 32-bit. Does the I340-F4 support 100base-FX SFP modules?
I am not sure if SFP modules are plug-and-play for different speeds / wavelengths.
As background, we currently are using I340-T4 cards with external media convertors between copper and the external 100base-FX systems, and are looking for a replacement card with support for 100base-FX so can avoid the need to user media convertors. The required number of ports, and available motherboard slots, limit us to quad port PCI express cards.
Mark_H_Intel
Hi Chester,
Unfortunately, Intel does not manufacture a NIC that meets your criteria. The I340-F4 optical modules are not pluggable and those modules support 1000BASE-SX only. They do not support any lower speeds or other wavelengths.
The X520 Converged Network Adapters support certain pluggable modules per http://www.intel.com/support/network/adapter/pro100/sb/CS-030612.htm Intel� Server Adapters — Which SFP+ modules, SFP modules, and cables can I use with the X520 Series? But those adapters only have two ports instead of four. And 100BASE-FX modules will not work on X520 adapters.
Mark
Mark_H_Intel
Hi Chester,
Mark
CGill4
Mark,
Thanks for the quick response. The Product Brief for the Intel Ethernet I340 Server Adapter says "Four high performing 10/100/1000 BASE-SX Ethernet connections (Fibre)" which is what made me think the I340-F4 may support different speeds. Guess that is an error in the product brief.
Mark_H_Intel
Hi Chester,
You are right. The product brief has an error. I will let the right people know so that it can be fixed. Thanks.
Mark H
CChan82
Dear Mark,
I am using the same model as Mr. Chester and facing the same problem.
could you check if someone fixed the product brief? or more people will be misled.
thanks!
Frank C
