I need driver Winpe 5 x86 for hp elitebook 840 g3.
I have test with E1D6332.inf it's don't work.
Where can i find the good driver?
Hi Stephane,
Checking on the HP elitebook 840 g3 specification, the onboard NIC is I219V or I219LM ethernet controller. Please try use the e1d6332.inf for the following version:
1) version 20.7
https://downloadcenter.intel.com/download/25892/Intel-Ethernet-Adapters-Connections-CD https://downloadcenter.intel.com/download/25892/Intel-Ethernet-Adapters-Connections-CD
Or
2) version 20.6
https://downloadcenter.intel.com/download/25747/Intel-Ethernet-Adapters-Connections-CD https://downloadcenter.intel.com/download/25747/Intel-Ethernet-Adapters-Connections-CD
If the driver still do not work, it is recommended still to contact notebook vendor HP* for the customized driver for OEM onboard NIC.
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006628.html?wapkw=oem+network http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006628.html?wapkw=oem+network
wb
Thanks for your answer.
It's don't work, i have test with the 20.7 and 20.6 it's the same.
I and contact m'y vendor HP, he can't help me.
What i can do? How can i have this driver?
Hi, please check the 20.7.1 driver package, kindly refer to the link below:
https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapters-Connections-CD https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapters-Connections-CD
after extraction, try to locate the needed driver in PRO1000\Winx64\NDIS64 folder.
regards,
Vince
it's don't work, it's the good driver for winPE 5.0 ( windows 8.1)
Hi, while i'm still checking for the requested driver, please share additional details on the problem or error you've encountered and the setup you wanted to implemented with the i219 ethernet controller. Thanks.
Vince
Hi, the required driver should be available in the NDIS64 folder, please share additional details on the problem or error you've encountered and the setup you wanted to implemented with the i219 ethernet controller.
Vince
