System details
I currently have 3 identical setups that all exhibit the same problem. Here is the configuration
- OS: ESXi 8.0.0 build 20513097 (latest 8.0a release)
- CPU: Intel Xeon E5-2697 v4
- Nic: E810-XXVDA2 in a PCIe Gen3 x8 slot
- Cables: HPE 845418-B21 QSFP28 breakout to 4x SFP28
- PBA: K57775-013
- Switch: Celestica DX010 32x100G running SONiC NOS
- ESXi Driver: 1.10.5.0-1OEM.702.0.0.17630552
- UEFI Driver: 4.0.25
- NVM: 4.10
- NVM ID: 0x80015188
Problem Statement
I have discovered a few issues with getting this nic to work on ESXi 8.
The biggest issue is the nic does not link up to my switch at 25G speeds. But is capable of linking up at 10G with a different breakout cable. I discovered that the "intnetcli" tool fails when trying to disable "Auto-FEC" mode (which I think is the culprit of the link issue):
[root@hyper-core7:~] esxcli intnet fec list
vmnic Requested FEC FEC
vmnic1 Auto-FEC No-FEC
vmnic2 Auto-FEC No-FEC
[root@hyper-core7:~] esxcli intnet fec set -m "No-FEC" -n vmnic2
Requested FEC mode is not supported. Refer to dmesg for more details.
[root@hyper-core7:~] dmesg | grep icen | tail -4
2023-01-13T18:53:46.313Z cpu26:2097304)icen: indrv_IsDcbEnabled:201: 0000:04:00.0: DCB is enabled, Major version 1, Minor version 1
2023-01-13T18:53:46.314Z cpu26:2097304)icen: indrv_IsDcbEnabled:201: 0000:04:00.1: DCB is enabled, Major version 1, Minor version 1
2023-01-13T18:55:03.942Z cpu13:3489616)WARNING: icen: icen_SetFec:13494: 0000:04:00.1: Requested FEC setting is not supported with the current link topology, Status: VMK_NOT_SUPPORTED
2023-01-13T18:55:03.942Z cpu13:3489616)icen: icen_SetFec:13502: 0000:04:00.1: Supported Fec modes: Auto-FEC
Workaround
- Boot into Windows OS
- Confirm links are still down
- Use Advanced Networking Properties to disable "Auto-FEC" mode on both ports
- Disable and Enable both links, wait for them to come up
- Warm reboot into ESXi
When I do this I no longer see "Auto-FEC" mode enabled in "intnetcli" tool on the ESXi hosts and the links stay up:
[root@hyper-core5:~] esxcli intnet fec list
vmnic1 No-FEC No-FEC
vmnic2 No-FEC No-FEC
However, this only works until the system is cold booted. So while this does get the systems up and running it is not ideal and leads me to not want to scale this solution out to more systems (as this would be very tedious on 3 systems let alone a rack full of systems).
Other issues:
- The latest version of "intnetcli" does not support ESXi 8 (only 6.7 up to 7.0, doesn't even support 7.1). Intel® ESXCLI Plug-In for Managing Intel® Ethernet Network Adapters
- I was able to extract the VIB and force install it to bypass the warnings
Open Questions:
- Is there a more permanent way to override the "Auto-FEC" mode (with an override in the EEPROM/NVM maybe)?
- Is there a way to force set the FEC mode (bypassing the validation)?
Additional Comments:
- No SFPs are detected on E810-xxvda4t - Intel Communities: This question was never resolved but the symptoms look very similar.
- HPE put out an advisory about this adapter having this exact same issue. However, I am unable to change the adapter FEC setting within ESXi and the option is missing from preboot/HII. Document - Advisory: HPE Network Adapters - Intel E810-XXVDA2 Ethernet 10/25Gb 2-port SFP28 Adapter for HPE May Not Link With Switches at 25Gb | HPE Support
- « Previous
- 1
- 2
- Next »
Hi Justin,
Good day and I hope this message finds you well!
This is just an another follow up on this thread. Please kindly let us know if you have any other assistance needed from this thread and we will assist you accordingly.
Do feel free to inquire us if you have any other questions that you may have and we will gladly assist you accordingly.
Faez.
Intel Customer Support
Hello Justin,
I hope you're having a wonderful day. I am just sending a follow up to check if you still have questions or clarifications. We will wait for your reply. As for now, we will be closing your thread.
If you want to continue support, please reply to this community thread and we will reopen your case or create a new one so that we can continue to support you.
Faez.
Hi Faez,
Hi I am from VMware and we are facing link-down issue with Ethernet Controller XXV710 for 25GbE SFP28
after the upgrade to VCF5.1/vSpheer8.0.2
Your intnet plugin in to esxcli doe not work and do not allow me to disable FEC.
I am using Intel Server S2600WF, so there is no UI for the card while booting from BIOS.
Is there way to modify setting on UEFI Shell?
Is there way to disable FEC with some other utility from ESXi shell?
You can find all versions and commands bellow:
- « Previous
- 1
- 2
- Next »
