Ethernet Products
5686 Discussions
E810-XXVDA4: Auto-negotiation doesn't work in 1000baseT/Full and 1000baseX/Full modes
YuanYan
Auto-negotiation of Salem Channel is verified in below environment.
After 2 Salem channel cards are negotiated to 25000Mb/s,
(1) Keep the settings of the card on machine A
(2) Change the supported modes of the card on machine B only
(3) Check if 2 cards can be negotiated to the specified modes.
Below are the results:
(1) Overall results: Auto-negotiation failed in 1000baseT/Full and 1000baseX/Full modes
Intel Ethernet Cards
Supported Modes
Advertise N
Ethtool command to set the speed
Result
Salem Channel
E810-XXVDA4
1000baseT/Full
0x020
ethtool -s ens11f0 advertise 0x020
FAIL. Link is down.
10000baseT/Full
0x1000
ethtool -s ens11f0 advertise 0x1000
PASS
25000baseCR/Full
0x80000000
ethtool -s ens11f0 advertise 0x80000000IPV4_LinkLED_AutoNegotiate_L
PASS
25000baseSR/Full
0x200000000
ethtool -s ens11f0 advertise 0x200000000
PASS
1000baseX/Full
0x20000000000
ethtool -s ens11f0 advertise 0x20000000000
FAIL. Link is down.
10000baseSR/Full
0x80000000000
ethtool -s ens11f0 advertise 0x80000000000
PASS
10000baseLR/Full
0x100000000000
ethtool -s ens11f0 advertise 0x100000000000
PASS
(2) Link can be up if 1000baseT/Full or 1000baseX/Full modes is set on both machine A and machine B.
Could you help to clarify this is a limitation or a bug?
Yuan
Below is some info for reference.
(1) Card info : see the attached pics
(2) Driver info
# ethtool ens11f0
Settings for ens11f0:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseT/Full
10000baseT/Full
25000baseCR/Full
25000baseKR/Full
25000baseSR/Full
1000baseX/Full
10000baseSR/Full
10000baseLR/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: None RS BASER
Advertised link modes: 10000baseT/Full
25000baseCR/Full
25000baseKR/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: None RS BASER
Link partner advertised link modes: Not reported
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 25000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Direct Attach Copper
PHYAD: 0
Transceiver: internal
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
# ethtool -i ens11f0
driver: ice
version: 1.9.11
firmware-version: 4.01 0x800135e3 1.3256.0
expansion-rom-version:
bus-info: 0000:70:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
IntelSupport
Community Manager
Hi YuanYan,
In order to better assist you, we recommend for you to provide below information:
  1. Are the Auto-negotiation is between machine A and B, or is between machine and switch?
  2. Is your machine Bios firmware and NIC driver updated to the latest?
  3. Is your machine and NIC come from OEM?
You may use the Ethernet Port Configuration Tool on below link to run the command "Get" to see the supported configurations of the NIC:
Ethernet Port Configuration Tool (All Supported OS)
https://www.intel.com/content/www/us/en/download/19436/ethernet-port-configuration-tool-windows.html
Fariz_Intel
IntelSupport
Community Manager
Hi YuanYan,
Fariz_Intel
YuanYan
Hi, Fariz_Intel
We have clarified the issue, thanks for your support.
Yuan
IntelSupport
Community Manager
Hi YuanYan,
If you have additional questions or clarifications, feel free to let us know.
We will contact you again within 3 business day for a follow-up. Looking forward to hearing back from you. Thanks.
Fariz_Intel
IntelSupport
Community Manager
Hi YuanYan,
Thanks for let us know, glad to hear it.
Thank you for choosing Intel.
Fariz_Intel
