Ethernet Products
5780 Discussions
Intel X520-1 VMQ not working in Windows 2022 Hyper-V server
mircolino
I just upgraded my homelab server to Windows Server 2022 and now I noticed that in Hyper-V VMQ doesn't work while SR-IOV works fine.
  • Host: Windows Server 2022 Standard build 20348.230
  • NIC: Intel X520-1 with firmware disabled
  • NIC driver: ixn68x64.sys v4.1.239.0
  • NIC link: trunk with LAN (VLAN 1 untagged), WAN (VLAN 2 tagged), DMZ (VLAN 3 tagged), IOT (VLAN 4 tagged)
PS C:\> Get-NetAdapterVmq -name "TRUNK" | fl
Caption                                 : MSFT_NetAdapterVmqSettingData 'Intel(R) Ethernet Server Adapter X520-1'
Description                             : Intel(R) Ethernet Server Adapter X520-1
ElementName                             : Intel(R) Ethernet Server Adapter X520-1
InstanceID                              : {D8C0261B-50B9-410D-8000-48CD898F2ED2}
InterfaceDescription                    : Intel(R) Ethernet Server Adapter X520-1
Source                                  : 2
SystemName                              : host.domain.com
AnyVlanSupported                        :
BaseProcessorGroup                      : 0
BaseProcessorNumber                     : 0
DynamicProcessorAffinityChangeSupported :
Enabled                                 : True
InterruptVectorCoalescingSupported      :
LookaheadSplitSupported                 : False
MaxLookaheadSplitSize                   : 0
MaxProcessorNumber                      :
MaxProcessors                           : 16
MinLookaheadSplitSize                   : 0
NumaNode                                : 65535
NumberOfReceiveQueues                   : 0
NumMacAddressesPerPort                  : 0
NumVlansPerPort                         : 0
TotalNumberOfMacAddresses               : 0
VlanFilteringSupported                  : True
PSComputerName                          :
ifAlias                                 : TRUNK
InterfaceAlias                          : TRUNK
ifDesc                                  : Intel(R) Ethernet Server Adapter X520-1
PS C:\> Get-VMSwitch -name "TRUNK" | fl
Notes                                            :
Extensions                                       : {Microsoft Windows Filtering Platform, Microsoft NDIS Capture}
BandwidthReservationMode                         : None
PacketDirectEnabled                              : False
EmbeddedTeamingEnabled                           : False
AllowNetLbfoTeams                                : False
IovEnabled                                       : True
SwitchType                                       : External
AllowManagementOS                                : True
NetAdapterInterfaceDescription                   : Intel(R) Ethernet Server Adapter X520-1
NetAdapterInterfaceDescriptions                  : {Intel(R) Ethernet Server Adapter X520-1}
NetAdapterInterfaceGuid                          : {d8c0261b-50b9-410d-8000-48cd898f2ed2}
IovSupport                                       : True
IovSupportReasons                                :
AvailableIPSecSA                                 : 2048
NumberIPSecSAAllocated                           : 0
AvailableVMQueues                                : 1
NumberVmqAllocated                               : 1
IovQueuePairCount                                : 127
IovQueuePairsInUse                               : 8
IovVirtualFunctionCount                          : 62
IovVirtualFunctionsInUse                         : 4
PacketDirectInUse                                : False
DefaultQueueVrssEnabledRequested                 : True
DefaultQueueVrssEnabled                          : True
DefaultQueueVmmqEnabledRequested                 : True
DefaultQueueVmmqEnabled                          : True
DefaultQueueVrssMaxQueuePairsRequested           : 16
DefaultQueueVrssMaxQueuePairs                    : 2
DefaultQueueVrssMinQueuePairsRequested           : 1
DefaultQueueVrssMinQueuePairs                    : 1
DefaultQueueVrssQueueSchedulingModeRequested     : StaticVrss
DefaultQueueVrssQueueSchedulingMode              : StaticVrss
DefaultQueueVrssExcludePrimaryProcessorRequested : False
DefaultQueueVrssExcludePrimaryProcessor          : False
SoftwareRscEnabled                               : True
RscOffloadEnabled                                : False
BandwidthPercentage                              : 0
DefaultFlowMinimumBandwidthAbsolute              : 0
DefaultFlowMinimumBandwidthWeight                : 0
CimSession                                       : CimSession: .
ComputerName                                     : Host
IsDeleted                                        : False
DefaultQueueVmmqQueuePairs                       : 2
DefaultQueueVmmqQueuePairsRequested              : 16
Every time I enable VMQ in one of the Hyper-V VM network adapters I always get the following system error ID 113:
Failed to allocate VMQ for NIC C1D9BEAE-5B79-4DC4-85DF-3269F631D047--8785038D-3198-469C-89C9-1088816B76C8 (Friendly Name: Network Adapter) on switch 2898A4DB-094D-4130-8A03-738B4FFFB9EF (Friendly Name: TRUNK). Reason - Maximum number of VMQs supported on the Protocol NIC is exceeded. Status = Insufficient system resources exist to complete the API.
Strangely SR-IOV works flawlessly.
Any idea how the fix the VMQ issue?
Rando
Same issue with Windows 2019
It is actually related to Switch Embedded Teaming  where it stops working.
Sintgle adapter and  LBFO teaming VMQ works without problem
Rando
Rando
Kalima
Up of this topic,
We currently make LCM of our Hyper-V Infrastructure to Server 2019/2022 and we use Switch Embedded Teaming for cisco ACI design.
We have exact same issue with this adapter.
Not solution will be provided from Intel ? It's a driver limitation I suppose.
Thank you and have a nice day,
JR6
So this is still an issue?  I know it is as I'm having it but notice this was posted in 2021.  For me:
- If I have LACP and PowerShell create the vSwitch ALL virtuals come back with VMQ active.  If I try to set to SR-IOV it shows degraded.
- If I use the proper Switch Embedded Teaming I have seen maybe one time that one VM enabled VMQ.  Other than that, they fail however any windows OS that is Windows 8 or newer will work with SR-IOV.  VMQ in general fails.  Basic message is Failed to allocate VMQ for NIC. Bla bla bla. Reason - VPort creation failed. Status = An invalid parameter was passed to a service or function.
So this shows in my environment both VMQ and SR-ioV is functional, just effected by the way the "teaming" is created for the NIC.  On the March of 2021 drivers.  So from everything I read Switch Embedded Teaming is the proper way to team your NICs and LACP is a no no especially since Microsoft blocks it thru their GUI now, but the card isn't working right with Switch Embedded Teaming.
I guess having VMQ active on all virtuals is a win, but at the cost of what seems to be incorrect configuration by today's standards on a LACP technology no longer being maintained in the OS.
By the way, before I try it, does the x710 adapter work right?  Anyone find a solution?
