Ethernet Products
5658 Discussions
E810 setup failed
suhehiro
Débutant
6 650 Visites
I'm reading and working on ice-1.8.8/README and irdma-1.8.46/README_irdma.txt, but I get an error during setup.
Below is my environment and the version I'm trying to install.
Ubuntu 20.04.4 LTS (GNU/Linux 5.4.0-113-generic x86_64)
ice-1.8.8
irdma-1.8.46
In "irdma-1.8.46/README_irdma.txt" The following error occurs in "5. Patch, build, and install rdma-core user space libraries:"
$ sudo dpkg -i ../*.deb
Selecting previously unselected package ibacm.
(Reading database ... 84286 files and directories currently installed.)
Preparing to unpack ../ibacm_35.0-1_amd64.deb ...
Unpacking ibacm (35.0-1) ...
Selecting previously unselected package ibverbs-providers:amd64.
Preparing to unpack .../ibverbs-providers_35.0-1_amd64.deb ...
Unpacking ibverbs-providers:amd64 (35.0-1) ...
Selecting previously unselected package ibverbs-utils.
Preparing to unpack .../ibverbs-utils_35.0-1_amd64.deb ...
Unpacking ibverbs-utils (35.0-1) ...
Selecting previously unselected package infiniband-diags.
Preparing to unpack .../infiniband-diags_35.0-1_amd64.deb ...
Unpacking infiniband-diags (35.0-1) ...
Selecting previously unselected package libibmad-dev.
Preparing to unpack .../libibmad-dev_35.0-1_amd64.deb ...
Unpacking libibmad-dev (35.0-1) ...
Selecting previously unselected package libibmad5-dbg.
Preparing to unpack .../libibmad5-dbg_35.0-1_amd64.deb ...
Unpacking libibmad5-dbg (35.0-1) ...
Selecting previously unselected package libibmad5.
Preparing to unpack ../libibmad5_35.0-1_amd64.deb ...
Unpacking libibmad5 (35.0-1) ...
Selecting previously unselected package libibnetdisc-dev.
Preparing to unpack .../libibnetdisc-dev_35.0-1_amd64.deb ...
Unpacking libibnetdisc-dev (35.0-1) ...
Selecting previously unselected package libibnetdisc5-dbg:amd64.
Preparing to unpack .../libibnetdisc5-dbg_35.0-1_amd64.deb ...
Unpacking libibnetdisc5-dbg:amd64 (35.0-1) ...
Selecting previously unselected package libibnetdisc5.
Preparing to unpack .../libibnetdisc5_35.0-1_amd64.deb ...
Unpacking libibnetdisc5 (35.0-1) ...
Selecting previously unselected package libibumad-dev:amd64.
Preparing to unpack .../libibumad-dev_35.0-1_amd64.deb ...
Unpacking libibumad-dev:amd64 (35.0-1) ...
Selecting previously unselected package libibumad3-dbg.
Preparing to unpack .../libibumad3-dbg_35.0-1_amd64.deb ...
Unpacking libibumad3-dbg (35.0-1) ...
Selecting previously unselected package libibumad3:amd64.
Preparing to unpack ../libibumad3_35.0-1_amd64.deb ...
Unpacking libibumad3:amd64 (35.0-1) ...
Selecting previously unselected package libibverbs-dev:amd64.
Preparing to unpack .../libibverbs-dev_35.0-1_amd64.deb ...
Unpacking libibverbs-dev:amd64 (35.0-1) ...
Selecting previously unselected package libibverbs1-dbg:amd64.
Preparing to unpack .../libibverbs1-dbg_35.0-1_amd64.deb ...
Unpacking libibverbs1-dbg:amd64 (35.0-1) ...
Selecting previously unselected package libibverbs1:amd64.
Preparing to unpack .../libibverbs1_35.0-1_amd64.deb ...
Unpacking libibverbs1:amd64 (35.0-1) ...
Selecting previously unselected package librdmacm-dev:amd64.
Preparing to unpack .../librdmacm-dev_35.0-1_amd64.deb ...
Unpacking librdmacm-dev:amd64 (35.0-1) ...
Selecting previously unselected package librdmacm1-dbg.
Preparing to unpack .../librdmacm1-dbg_35.0-1_amd64.deb ...
Unpacking librdmacm1-dbg (35.0-1) ...
Selecting previously unselected package librdmacm1:amd64.
Preparing to unpack ../librdmacm1_35.0-1_amd64.deb ...
Unpacking librdmacm1:amd64 (35.0-1) ...
Selecting previously unselected package python3-pyverbs.
Preparing to unpack .../python3-pyverbs_35.0-1_amd64.deb ...
Unpacking python3-pyverbs (35.0-1) ...
Selecting previously unselected package rdma-core.
Preparing to unpack ../rdma-core_35.0-1_amd64.deb ...
Unpacking rdma-core (35.0-1) ...
Selecting previously unselected package rdmacm-utils.
Preparing to unpack .../rdmacm-utils_35.0-1_amd64.deb ...
Unpacking rdmacm-utils (35.0-1) ...
Selecting previously unselected package srptools.
Preparing to unpack ../srptools_35.0-1_amd64.deb ...
Unpacking srptools (35.0-1) ...
Setting up libibumad3:amd64 (35.0-1) ...
Setting up libibverbs1:amd64 (35.0-1) ...
Setting up librdmacm1:amd64 (35.0-1) ...
Setting up rdma-core (35.0-1) ...
rdma-hw.target is a disabled or a static unit, not starting it.
rdma-ndd.service is a disabled or a static unit, not starting it.
Job for iwpmd.service failed because a timeout was exceeded.
See "systemctl status iwpmd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript iwpmd, action "start" failed.
● iwpmd.service - iWarp Port Mapper
     Loaded: loaded (/lib/systemd/system/iwpmd.service; static; vendor preset: enabled)
     Active: failed (Result: timeout) since Tue 2022-06-28 07:01:21 UTC; 13ms ago
       Docs: man:iwpmd
             file:/etc/iwpmd.conf
    Process: 14310 ExecStart=/usr/sbin/iwpmd --systemd (code=exited, status=0/SUCCESS)
   Main PID: 14310 (code=exited, status=0/SUCCESS)
Jun 28 06:59:51 host1 systemd[1]: Starting iWarp Port Mapper...
Jun 28 06:59:51 host1 iwpmd[14310]: get_iwpm_param: Got param (name = nl_sock_rbuf_size val = 419430400)
Jun 28 07:01:21 host1 systemd[1]: iwpmd.service: start operation timed out. Terminating.
Jun 28 07:01:21 host1 iwpmd[14310]: iwpm_signal_handler: Received SIGTERM signal
Jun 28 07:01:21 host1 systemd[1]: iwpmd.service: Failed with result 'timeout'.
Jun 28 07:01:21 host1 systemd[1]: Failed to start iWarp Port Mapper.
dpkg: error processing package rdma-core (--install):
 installed rdma-core package post-installation script subprocess returned error exit status 1
Setting up rdmacm-utils (35.0-1) ...
dpkg: dependency problems prevent configuration of srptools:
 srptools depends on rdma-core (>= 15); however:
  Package rdma-core is not configured yet.
dpkg: error processing package srptools (--install):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of ibacm:
 ibacm depends on rdma-core (>= 15); however:
dpkg: error processing package ibacm (--install):
Setting up ibverbs-providers:amd64 (35.0-1) ...
Setting up ibverbs-utils (35.0-1) ...
Setting up libibmad5 (35.0-1) ...
Setting up libibnetdisc5 (35.0-1) ...
Setting up libibumad-dev:amd64 (35.0-1) ...
Setting up libibumad3-dbg (35.0-1) ...
Setting up libibverbs-dev:amd64 (35.0-1) ...
Setting up libibverbs1-dbg:amd64 (35.0-1) ...
Setting up librdmacm-dev:amd64 (35.0-1) ...
Setting up librdmacm1-dbg (35.0-1) ...
dpkg: dependency problems prevent configuration of python3-pyverbs:
 python3-pyverbs depends on rdma-core (>= 21); however:
dpkg: error processing package python3-pyverbs (--install):
Setting up infiniband-diags (35.0-1) ...
Setting up libibmad-dev (35.0-1) ...
Setting up libibmad5-dbg (35.0-1) ...
Setting up libibnetdisc-dev (35.0-1) ...
Setting up libibnetdisc5-dbg:amd64 (35.0-1) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.7) ...
Processing triggers for systemd (245.4-4ubuntu3.15) ...
Errors were encountered while processing:
 rdma-core
 srptools
 ibacm
 python3-pyverbs
The network settings and dmsg are also attached.
I tried it because rping is installed, but the following error occurs only for host1.
rdma-core-35.0/build/bin$ ./rping -sdvVa 172.16.0.241
verbose
validate data
created cm_id 0x555acb4e9a30
libi40iw-i40iw_ualloc_context: failed to allocate context for device.
rdma_bind_addr: No such device
destroy cm_id 0x555acb4e9a30
Étiquettes (1)
0 Compliments
6 Réponses
Caguicla_Intel
Modérateur
6 626 Visites
Hello suhehiro,
Before we check the issue with our engineers, can you share how many adapters are involved on this request? Can you also provide the exact model of your E810 adapter? Do you see any Yottamark or BradyID sticker from adapter? The sticker is an authentication label for Intel Ethernet adapters.
Hoping to hear from you soon.
Should there be no response, we will follow up after 3 business days.
Crisselle C.
Intel® Customer Support
0 Compliments
suhehiro
Débutant
6 582 Visites
There is one network adapter for each server.
There are four ethernet ports on the motherboard, one of which is connected to the local network.
The E810 connects servers to each other without going through a switch.
Model is E810-CQDA2.
I didn't know the sticker, so I'll attach a photo.
0 Compliments
Caguicla_Intel
Modérateur
6 570 Visites
Hello suhehiro,
Thank you for providing the requested information.
Please allow us to check this further. We will give you an update as soon as possible but no later than 3 business days.
Hoping for your kind patience.
Crisselle C.
Intel Customer Support
0 Compliments
Caguicla_Intel
Modérateur
6 552 Visites
Hello suhehiro,
Thank you for the patience on this matter.
Please see below feedback from our engineers and let us know if you have questions or clarifications.
Can you try the latest ice 1.8.9 from link below then try irdma again?
Intel Ethernet Drivers and Utilities - Browse /ice stable/1.8.9 at SourceForge.net
https://sourceforge.net/projects/e1000/files/ice%20stable/1.8.9/
Based on the photos of the card, you are using HPE Original Equipment Manufacturer(OEM) version of Ethernet adapter. For OEM version of Ethernet adapters, we'd like to set your expectation that we have a limited support it would be best if you can get in touch with HP for further support since they have customized drivers, firmware and software to enable or alter features on your card. They are in best position where you can seek assistance so you don’t lose features or customizations of the Ethernet adapter.
Awaiting to your reply.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
0 Compliments
Caguicla_Intel
Modérateur
6 506 Visites
Hello suhehiro,
Good day!
This is just a follow up to check if you read our latest update. If yes, please confirm and let us know if you have additional questions or assistance needed on this matter.
Crisselle C.
0 Compliments
Caguicla_Intel
Modérateur
6 481 Visites
Hello suhehiro,
I hope this message finds you well!
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you for choosing Intel and stay safe!
Crisselle C.
0 Compliments
Répondre
