- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
We are trying to use SR-IOV on the Intel XL710 cards (2-port, 40G) and have issue with initialization.
According to https://doc.dpdk.org/guides/nics/i40e.html, the matching FW version for the DPDK version (17.02) we are using should be 5.05, and firmware on my card is 6.03.
So I was trying to downgrade the XL710 firmware from 6.03 to 5.05 using the Linux version of nvmupdate64e, but I forgot to shutdown the VM which is using the card, and the update failed.
Trying to recover, I shut down the machine completely, and the power the system back up. Now I will get the following error message during the boot:
[ 2.736693] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.6.27-k
[ 2.736695] i40e: Copyright (c) 2013 - 2014 Intel Corporation.
[ 6.720801] i40e 0000:04:00.0: fw 6.0.48442 api 1.7 nvm 5.05 0x800028a6 1.1747.0
[ 6.720803] i40e 0000:04:00.0: The driver for the device detected a newer version of the NVM image than expected. Please install the most recent version of the network driver.
[ 6.952890] i40e 0000:04:00.0: capability discovery failed, err OK aq_err I40E_AQ_RC_EMODE
[ 10.961130] i40e 0000:04:00.1: fw 6.0.48442 api 1.7 nvm 5.05 0x800028a6 1.1747.0
[ 10.961137] i40e 0000:04:00.1: The driver for the device detected a newer version of the NVM image than expected. Please install the most recent version of the network driver.
[ 11.191554] i40e 0000:04:00.1: capability discovery failed, err OK aq_err I40E_AQ_RC_EMODE
What should I do to recover the NIC? Your help are greatly appreciated.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Your link is bad.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Here is the link again:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Jing,
We would like to check if the suggestions of our esteemed community members addressed your concern.
We look forward to hearing from you. Should we not hear from you, we will follow up after 3 business days.
Alfred S
Intel® Customer Support
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Jing,
Thank you for your response.
We are sorry to know that you are still experiencing the issue.
Please allow us to ask more questions; in this way, we can determine what would be the best recommendation for your concern:
1. May we know the exact model of the Intel XL710?
2. We need to know if your card is an OEM variant or our very own retail variant. OEM variants may have different firmware than the retail versions. To determine this, if possible, kindly give us a picture focusing on the markings printed on the different stickers on the card. There will also be marking embossed or printed on the card’s circuit board, please also provide a picture of it.
We look forward to your reply. Should we not get your reply, we will follow up after three business days.
Alfred S
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Alfred,
Thanks for your help.
We have a XL710-QDA2 card.
Here are a couple of pictures for the 40G NIC we are using.
Sam
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Sam65021,
Kindly provide us the results of this command: ethtool -i ethx where ethx is the Ethernet port.
Alfred S
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Alfred,
The 40G Ethernet card is not recognized, so I can not run ethtool command on it.
The dmesg output is list below.
Sam
[ 2.738019] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.6.27-k
[ 2.738021] i40e: Copyright (c) 2013 - 2014 Intel Corporation.
[ 6.701470] i40e 0000:04:00.0: fw 6.0.48442 api 1.7 nvm 5.05 0x800028a6 1.1747.0
[ 6.701473] i40e 0000:04:00.0: The driver for the device detected a newer version of the NVM image than expected. Please install the most recent version of the network driver.
[ 6.933172] i40e 0000:04:00.0: capability discovery failed, err OK aq_err I40E_AQ_RC_EMODE
[ 10.942043] i40e 0000:04:00.1: fw 6.0.48442 api 1.7 nvm 5.05 0x800028a6 1.1747.0
[ 10.942046] i40e 0000:04:00.1: The driver for the device detected a newer version of the NVM image than expected. Please install the most recent version of the network driver.
[ 11.172354] i40e 0000:04:00.1: capability discovery failed, err OK aq_err I40E_AQ_RC_EMODE
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Sam65021,
We are already starting for look closely on your issue. We have questions for your to aid us in find a recommendation for your concern. Please answer the following questions:
1. May we know the exact Linux based OS that you are using?
You may run our Intel® System Support Utility from this page, https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System#:~:text=Intel%20SSU%20for%20the%20Linux,and%20shared%20by%20the%20user. After running it, you will be given an option to save the logs to a text file, please do so and attach the file on your reply, in this way, we will be the ones to check the OS version.
2. To confirm are you already using the most updated network driver for your Linux OS?
3. If you have already updated it, please try to uninstall the current driver and perform a clean install of the driver on your system and see if the same error occurs. If the same error happens, please try to use an older driver version and see if that bypasses the error message.
Alfred S
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Alfred,
1. We are using Redhat Enterprise Linux 7.4
john@redhat-linux ~]$ cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.4 (Maipo)
2. The driver version is 1.6.27
[john@redhat-linux ~]$ modinfo i40e
filename: /lib/modules/3.10.0-693.el7.x86_64/kernel/drivers/net/ethernet/intel/i40e/i40e.ko.xzversion: 1.6.27-k
3. Note that the card works fine until I tried to downgrade the firmware using nvmupdate64e.
4. If I run nvmupdate64e, I will get the following error message:
[john@redhat-linux Linux_x64]$ sudo ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.30.22.3
Copyright (C) 2013 - 2017 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [*.........]
Num Description Ver. DevId S:B Status
01) Intel(R) I350 Gigabit Network Connection 1.72 1521 00:002 Update not
available
02) Intel(R) Ethernet Converged Network 1583 00:004 Access error
Adapter XL710-Q2
Tool execution completed with the following status: Device not found
Press any key to exit.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Sam65021,
Thank you for your response and providing more details regarding the issue,
We will continue checking this and the information that provided is invaluable to us.
Please allow us some time to check on this. We hope for your understanding regarding this
We will get back to you no later than 3 business days from now.
Alfred S
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Sam65021,
Thank you for your patience in waiting for an update.
Due to the complexity of the issue, please allow us more time to check on your concern.
We will try to get back to you with an answer no later than 3 business days from now; although, we will reach out to you in case we need more information or if we already have developments regarding your concern.
Alfred S
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi sam65021,
Thank you for waiting for our update.
While we were closely checking your concern, we find the need to get a more extensive look at your network adapter due to the reason that firmware version 6.03 is not available on our download center for the card model that you are reporting, as we only have version 6.01 then after that 6.80. You may refer to this page for confirmation, https://downloadcenter.intel.com/download/24769/Non-Volatile-Memory-NVM-Update-Utility-for-Intel-Ethernet-Network-Adapter-700-Series.
For this reason, we would like to make sure about the model of your card.
Hence, we need to get the PBA number from your card. We need to determine if it is a retail adapter or if you have a different version. Having a different version means that it also needs a distinct firmware package compared to the one found on our download center.
Consequently, please provide us with pictures of the markings printed on the stickers on the card. Kindly provide us with pictures focusing on the characters printed on the sticker and the PBA number printed on the circuit board of the card.
Alfred S
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi sam65021,
Alfred S
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Sam65021,
We are just following up.
It looks like you need more time to provide the information that we asked.
We will follow up again after 3 business days. Should we not hear from you, our system may automatically close the thread.
Alfred S
Intel Customer Support
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Sam65021,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers. We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
