hi,
we are running a windows r2 2012 machine with Gigabit 4P I350-t network Adapter attached.
All physical ports are connected to a juniper EX4300 Ethernet Switch, with windows teaming enable:
windows teaming setup:
teaming mode set to : LACP
load balancing mode set to :dynamic
we are getting this error on the event viewer :
Miniport Intel(R) Gigabit 4P I350-t Adapter, {0b4775c9-0b0a-437e-8b3d-aeee7f5c91cd}, had event Fatal error The miniport has detected an internal error
the error appear on a daily basis what case to the network driver to get crashed and lose connectivity .
see windows event viewer log:
Log Name System
Source Microsoft-Windows-NDIS
Date 932015 80144 PM
Event ID 10317
Task Category PnP
Level Error
Keywords (16384),(16),(4),(2)
User SYSTEM
Computer Output
Description
Event Xml
Event xmlns=httpschemas.microsoft.comwin200408eventsevent
System
Provider Name=Microsoft-Windows-NDIS Guid={CDEAD503-17F5-4A3E-B7AE-DF8CC2902EB9}
EventID10317EventID
Version0Version
Level2Level
Task2Task
Opcode0Opcode
Keywords0x2000000000004016Keywords
TimeCreated SystemTime=2015-09-04T010144.151466500Z
EventRecordID94540EventRecordID
Correlation ActivityID={0B4775C9-0B0A-437E-8B3D-AEEE7F5C91CD}
Execution ProcessID=4 ThreadID=3244
ChannelSystemChannel
ComputerOutputComputer
Security UserID=S-1-5-18
System
EventData
Data Name=IfGuid{0B4775C9-0B0A-437E-8B3D-AEEE7F5C91CD}Data
Data Name=IfIndex22Data
Data Name=IfLuid1688850212585472Data
Data Name=AdapterNameIntel(R) Gigabit 4P I350-t AdapterData
Data Name=MiniportEventEnum71Data
EventData
Event
we already tried the above:
check Ethernet cable,
update driver to latest one
tried both teaming method: windows teaming and Intel driver teaming ,problem keep persist.
any idea how to resolve this?
Hi Amitg,
Since you have configured LACP, make sure to configure link aggregation on the switch ports where the adapter is connected. If you continue to encounter same issue, please provide us the driver and ANS version you have installed.
In case you wish to update the driver, you may download the latest driver here - https://downloadcenter.intel.com/download/23073/Network-Adapter-Driver-for-Windows-Server-2012-R2- Network Adapter Driver for Windows Server 2012 R2*
Sincerely,
Sandy
