Ethernet Products
5705 Discussions
How do you config DPDK testpmd to forward packets?
ROdle
Trying to config DPDK for x710 first time. testpmd says packets received and that it sends packets. We are running on Supermicro server with AMD Epyc with quad X710 Intel 10G interfaces. Running dpdk in VM using SRIOV interfaces. testpmd can receive packets and send packets (txonly) but there is 100% loss when forwarding packets. --log-level=8 does show that testpmd is trying to forward packets.
Caguicla_Intel
Hello ROdle, Thank you for posting in Intel Ethernet Communities. Since this question involves DPDK, please check with Intel Premier Support. See the following for access to Intel Premier Support. Click the "Login and Access" to contact the DPDK support" https://www.intel.com/content/www/us/en/design/support/ips/training/access-and-login.html Please let us know if you have any other questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
BillXiang
Hello, have you resolved this?
