Ethernet Products
5672 Discussions
How to change the tx queue value in ixgbevf driver ?
axiao
my question is :
environmet :82599 intel Ethernet Controller, EXSI system in host and ubuntu in Client,and my system require dpdk
when i build the ixgbe in host successfully,and bind vf in ubuntu ,i find the queue in vf is only 1 in both tx and rx,
then i change the rss=8,8,MQ=1,1 in host,but it has no effect on the queue value of vf unit ,dpdk can't work in my system,i want to change the tx queue to 8,how to do it ?
Hi Intel_Xiao,
Thank you for posting at Wired Communities. For Intel® DPDK related questions and technical problems, you may report through the Intel® Premier Support site
http://premier.intel.com/premier or access your IBL account and click
the Intel® Premier Support link to enter issues under the Product Name
"Data Plane Development Kit (DPDK)", which are then routed to our support team.
Hope this helps.
Rgds,
sharon
