Ethernet Products
5671 토론
How to configure VLAN Id in Windows 7 Pro?
AFiel4
초보자
15,926 조회수
I have an Intel 82566DM-2 Gigabit NIC in a HP desktop running Windows 7 Pro 32-bit.
How do I configure a LAN configuration to have a specific VLAN id? Is there any utility available/needed?
0 포인트
5 응답
Mark_H_Intel
직원
9,510 조회수
When you install Advanced Network Services (ANS) as part of the default software installation, you get a VLAN tab in Windows Device Manager where you can configure the VLAN ID. You might have the tab now. Just look at the device properties and look for the VLAN tab.
You can get the latest WIndows 7 software at http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18713 http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18713.
Mark H
0 포인트
AFiel4
초보자
9,510 조회수
Thanks!
I downloaded and installed ProWin32.exe (Intel Network Connections 18.2.63.0 reported in Programs and Features), but I still see only four tabs: General, Driver, Details, Power Management, even after rebooting. Did I do anything wrong or is there something else I should have done?
0 포인트
Mark_H_Intel
직원
9,510 조회수
I'm not sure why you can't see the VLAN tabs. Maybe PROSet and ANS are not being installed when you run the installation package. Those are usually checked by default, but if you only had the base drivers, then you migtht have to manually check those options. Those are the options higlighted in yellow below.
If PROSet and ANS are checked when you install, but you still can't see the tabs, then I would try removing all components of the installation using the Windows Control Panel. Tgeb rebott and install the drivers and software from scratch.
http://www.intel.com/support/network/sb/CS-030604.htm Network Connectivity — Intel� PROSet configuration tabs are missing has information about a required service for the tabs to be displayed. Maybe the Windows Management Instrumentation service is being blocked on your PC for some reason.
I can't think of any other reasons why you wouldn't see the VLAN tab.
Mark H
0 포인트
AKene
초급자
9,510 조회수
I have installed Advanced Network Services and can see VLAN tab in Windows Device Manager.
I have added a VLAN 12 but the VLAN 12 interface still disconnected, see below :
0 포인트
AKene
초급자
9,510 조회수
I have assigned an IP address to the VLAN 12 interface but from the PC, I can't even ping the VLAN 12 ip address
0 포인트
응답
