Ethernet Products
5738 Discussions
How to create a VEB and VSI on the XL710
LeslieSu
Hello
I'm using the Intel XL710 network card recently, but I don't know how to create a VEB or how to bind two VFs or a PF and a VF to the same VEB/VEPA.
I want to know how to create VSI? How to match VSI and VF?
The system used is CentOS 7.9 linux kernel - 5.4
Shaq_Intel
Hi LeslieSu,
Thank you for contacting Intel Customer Support for Ethernet Product. As for your question you can try the method below and let us know if it help.
To create a VEB (Virtual Ethernet Bridge), you can use the following steps:
1. Load the ixgbe driver using the modprobe command:
modprobe ixgbe
2. Create the VEB using the ip link command:
bash
ip link add name <VEB_NAME> type bridge
3. Add the PF or VF to the VEB:
arduino
ip link set <PF_NAME_or_VF_NAME> master <VEB_NAME>
To bind two VFs or a PF and a VF to the same VEB/VEPA, you can follow the same steps as above, but you need to add both the VFs or PF and VF to the same VEB using the ip link set command.
To create a VSI (Virtual Station Interface), you can use the following steps:
1. Enable SR-IOV (Single Root Input/Output Virtualization) on the network card:
Javascript
echo 1> /sys/class/net/<PF_NAME>/device/sriov_numvfs
2. Create the VSI using the ip link command:
Bash
ip linkadd name <VSI_NAME> typemacvlan mode passthru
3. Assign the VF to the VSI:
arduino
ip link set <VF_NAME> netns <VSI_NAME>
To match VSI and VF, you need to use the same naming convention for the VSI and VF names. For example, if you create a VF named eth0_1 using the ip link command, you should create a VSI with the same name (eth0_1) using the steps mentioned above.
Note: The above steps are specific to the Intel XL710 network card and may not work with other network cards. It's always a good idea to refer to the network card's documentation for specific instructions.
Shaq_Intel
Charlie_Chan
Thanks for your answer, Shaq. I'm also searching for methods of creating VEBs for my X710 nic. This would be a help for me.
But I wonder if ixgbe is a must-be kmod for VEB, or i40e is also ok? As I know ixgbe is for 500 series NICs.
And I also wonder, when using "ip link add name <VEB_NAME> type bridge" to create veb, will it create a linux sw bridge, or it will turn into the hw-based veb in the nic while the correct nic kmod is loaded?
Shaq_Intel
Hi LeslieSu,
As for your question, i would suggest you to ask our developer and embedded communities. As that communities post will help you with more in depth question.
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
As i will closing this thread for now. Thank you.
Shaq_Intel
