Ethernet Products
5707 Discussions
I want to know how to monitor the VF of SR-IOV?
CChen375
my physical network card ens1f0 is on HP C7K card
driver: ixgbe, version is 5.1.0-k-rh7.5
in my ENV, I enable 64 VF, however, I only use 22 VF and each VF has the below configuration:
vf 49 MAC fa:16:3e:b0:6e:d0, vlan 114, spoof checking on, link-state auto, trust off, query_rss off
once I trigger a huge traffic on some of them, then the rest will be impact.
fg, it can't ping gw, however, after around 10 minutes, then it can ping gw again. this issue will keep there until reboot physical host.
since this is remote system, I can't trace packet on router, so do you have any way to approve the ping request is sent out from physical host to switch? I can only see by TCPdump on guest VM and the ping request is sent out. so howto know where the packet is dropped.
thanks in advance!
CLiff 2019/12/10
Caguicla_Intel
Hello Cliff,
Thank you for posting in Intel Ethernet Communities. Please provide the following details for us to check on your query.
1.) Exact model of the Ethernet adapter. You may provide the PBA number of the adapter for us to double check on it. This would help us identify if you are using an OEM or retail version of Intel Ethernet Adapter. You may refer to the link below on where you can locate the PBA. It consists of 6-digit number located at the last part of the serial number.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-io/ethernet-products.html
2.) What is the Operating system used?
3.) Please share the link where the driver was downloaded.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
Caguicla_Intel
Hello Cliff,
Good day!
Please provide the requested information for us to proceed in checking your request.
Awaiting to your reply.
Crisselle C
CChen375
Thanks for quick answer:
For your question:
1) PBA, I can't provide it now because lib is in other country and I have to query that
does this output meet your needs?
lspci -vv -s 09:00.0| grep -i pba
               PBA: BAR=3 offset=00002000
2) The os is
uname -a
Linux overcloud-sriovperformancecompute-10 3.10.0-862.9.1.el7.x86_64 #1 SMP Mon Jul 16 16:29:36 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
3) I think Driver is download with OS.
ethtool -i ens1f0
driver: ixgbe
version: 5.1.0-k-rh7.5
firmware-version: 0x80000886
expansion-rom-version:
bus-info: 0000:09:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
thanks in advance!
Cliff
Caguicla_Intel
Hello Cliff,
You are welcome.
Please provide the the exact model of the adapter that you are requesting for assistance as well as the System Support Utility log of your system for us to check if the PBA will be captured.
a- Go to https://downloadcenter.intel.com/product/91600/Intel-System-Support-Utility and download the software.
b- Refer to this link for the instructions on how to extract the logs
https://www.intel.com/content/www/us/en/support/articles/000008563/software/software-applications.html
Crisselle C
CChen375
hi Crisselle,
I think we are in the wrong direction. the network card in C7K used is from HP not Intel.
however, the driver is ixgbe from Intel.
so I can't find PBA with MYI63705NM, right?
see below
lspci -v -s 09:00.0
09:00.0 Ethernet controller: Intel Corporation 82599 10 Gigabit Dual Port Backplane Connection (rev 01)
       Subsystem: Hewlett-Packard Company Ethernet 10Gb 2-port 560M Adapter
       Physical Slot: 1
       Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
       Memory at 92c00000 (32-bit, non-prefetchable) [size=1M]
       I/O ports at 2020 [size=32]
       Memory at 92d04000 (32-bit, non-prefetchable) [size=16K]
       [virtual] Expansion ROM at 92d80000 [disabled] [size=512K]
       Capabilities: [40] Power Management version 3
       Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
       Capabilities: [70] MSI-X: Enable+ Count=64 Masked-
       Capabilities: [a0] Express Endpoint, MSI 00
       Capabilities: [e0] Vital Product Data
       Capabilities: [100] Advanced Error Reporting
       Capabilities: [140] Device Serial Number 14-02-ec-ff-ff-79-f8-30
       Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
       Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
       Kernel driver in use: ixgbe
       Kernel modules: ixgbe
thanks
Cliff
Caguicla_Intel
Hello Cliff,
Thank you for the reply.
Since you mentioned that this is an Ethernet adapter from HP (an Original Equipment Manufacturer (OEM) version of Intel Ethernet adapter), we would suggest to contact HP for further assistance and for the correct driver to be installed on your system. They are in best position where you can seek assistance so you don’t lose features or customizations of your Ethernet adapter.
You may visit this link for the List of Supported Retail Intel® Ethernet Adapters
https://www.intel.com/content/www/us/en/support/articles/000005612/network-and-io/ethernet-products.html
Let us know if you have any other assistance needed form Intel Ethernet team.
Crisselle C
