Ethernet Products
5779 Discussions
I210 AVB Timers
GSing13
Hello All,
I am not sure if this is the correct forum to post my question and I would be thankful if someone can point me to the correct one if the question is not relevant.
The question I want to ask is related to the Intel i210-AT chip which I am using for my Industrial solution. I am writing a new Linux driver for the External NIC, which has the i210 chip, for handling packets in a time critical network.
I am using the Time SYNC (section 7.8 in the Intel® Ethernet Controller I210 Datasheet) registers i.e. SYSTIM, TRGTTIML/H0 and TRGTTIML/H1 to create timers using the method explained in "7.8.3.3.1 SYSTIM Synchronized Level Change Generation on SDP Pins"
The timers created are used by the Linux drivers to synchronize the packet transmission in the SR mode (i.e. using launchTime).
I have completed the implementation and the setup works fine if the timers are created in a non-periodic sequence. The problem arises if I try to reset the values or increment the timeout for the timers periodically where the period is lesser than the timeout values.
I am not sure if I have presented my problem correctly here. I would be happy to share other details to clarify the implementation details.
Gaurav
SYeo3
Valued Contributor I
Hi Gaurav,
Thank you for contacting Intel. I'll check on this.
Sincerely,
Sandy
GSing13
Hi Sandy,
Do you have any updates for me on the above query?
Gaurav
