Ethernet Products
5661 Discusiones
INTEL I350T2 PROBLEM WINDOWS 11
Nico68
Principiante
1.069 Vistas
I have the card PCI EXPRESS I350T2V2,
when I had WINDOWS 10 it worked perfectly with LINK AGGREGATION configured by WINDOWS POWERSHELL, since I upgraded the computer to WINDOWS 11 I can't install the card with the static LINK AGGREGATION between the ports.
Is there a way? can you help me?
Thank you
0 kudos
3 Respuestas
Shaq_Intel
Empleados
1.035 Vistas
Hi Nico68,
As for this is Windows Related Issue, I suggest that you contact the windows support for this issue. As the card is the same and the OS is the one that cause the issue after the update. But i can suggest you to update the driver if possible. Refer to the link below for the driver update. I will keep this thread open first and just update if you still need help from our end.
https://www.intel.com/content/www/us/en/products/sku/84804/intel-ethernet-server-adapter-i350t2v2/downloads.html
Shaq_Intel
Shaq_Intel
Empleados
1.007 Vistas
Hi Nico68,
Good day and I hope everything is great!
This is just a follow up regarding the issue of your reported with us.
If you have additional questions or clarifications, feel free to let us know.
Should there be no response from you, I’ll make sure to reach out within 2 business day.
Let us know if there are any preferred date/time to reach you so that we can revert accordingly. Thanks.
Shaq_Intel
Shaq_Intel
Empleados
977 Vistas
Hi Nico68,
Good day and hope that you are doing well.
This is just a follow up regarding the issue of your reported with us. We know that this is important for you to get it resolved and it is also equally important for us to get you the right solution.
Since we have not seen an update for several days, hence we will proceed with the case closure. If you need any additional information, please submit a new question as this thread will no longer be monitored
Have a good day and Thank you for reaching out to Intel Support.
Shaq_Intel
Responder
