Ethernet Products
5744 Discussions
Intel 10G 82599EB - unable to enable PXE
PvanV
Hi Guys,
I am trying to enable PXE for an Intel 82599EB 10-Gigabit SFI/SFP+ Network card.
I am running Linux CentOS 6.4
lspci | grep -i network
02:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
02:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
82:00.0 Ethernet controller: Intel Corporation 82599EB 10-Gigabit SFI/SFP+ Network Connection (rev 01)
82:00.1 Ethernet controller: Intel Corporation 82599EB 10-Gigabit SFI/SFP+ Network Connection (rev 01)
I have downloaded the latest "bootutil" [BootUtil version 1.4.17.4]
According to the specs for this type of network chip, it should be able to do PXE booting.
I have enabled Intel 10G cards in the past with the "bootutil" program, but it won't enable this type of card:
./bootutil64e -flashenable -nic=3
Intel(R) Ethernet Flash Firmware Utility
Copyright (C) 2003-2012 Intel Corporation
Enabling boot ROM on port 3...
ERROR: Unsupported feature
Port Network Address Location Series WOL Flash Firmware Version
1 7845C4F849D7 2:00.0 Gigabit NO FLASH Not Present
2 7845C4F849D8 2:00.3 Gigabit YES FLASH Not Present
3 008CFA18A152 130:00.0 10GbE N/A FLASH Not Present
4 008CFA18A153 130:00.1 10GbE N/A FLASH Not Present
./bootutil64e -bootenable=pxe -nic=3
Option ROM area in the flash is not supported for this device on port 3
It looks like that there is no firmware present on this card.
[I could not find any info how to put firmware on this card]
Any idea how to enable PXE for this Intel network chip?
Pieter
Mark_H_Intel
Hi PIeter,
Is the NIC a built-in NIC or an adapter plugged into a PCIe connector? I suspect that your system has the connection built in. You might be dependant on whatever tool the system manufacturer has for supporting PXE.
Mark H
Mark_H_Intel
Hi PIeter,
Mark H
PvanV
Hi Mark,
Thanks for pointing me to the solution.
The NIC is located on a mezzanine card, so not really a standalone card.
I found a firmware update from the manufacturer and I updated/installed the firmware with the eeupdate tool under MSDOS.
eeupdate.exe /nic=3 /D 82599_~1.txt
eeupdate.exe /nic=4 /D 82599_~1.txt
The 10g card is now PXE capable.
Pieter
