Ethernet Products
5734 Discussions
Intel Communication: Intel® Ethernet Controller I226 Series-Random connection drops at random times
Cam__Intel
Some customers have recently reported connection drops at random times, specifically on the newly launched 700 series motherboards with Intel® Ethernet Controller I226-V.
Intel has reproduced the issue and is diligently working on a root cause and fix. For any of our customers experiencing this problem, a mitigation option to explore is to disable the “Energy Efficient Ethernet (EEE)” mode in the Advanced Windows/ Linux driver setting.  We believe this should help. We are continuing to assess the situation and will follow-up accordingly.
We appreciate those who have shared information about their experience with this issue, and we welcome your input.  Intel will continue to review the comments and information you share to help us work towards a solution.
Intel
warham
mega.nz/file/pc91lSrD#YG83fKF78opshdBvkzr-KVOKNHtFEvROpkOOwtCVIBs
Polezzz
Greetings,
This is my experience.
I have been there for less than a month this config:
ASUS TUF GAMING Z790-PRO WIFI (BIOS V.1424) + Intel i5@13600k + 32GB RAM DDR5 XMP3.0 6400mt/s cl32 Fury Renegade + SSD M2 990 Pro 1 TB + SSD M2 980 Pro 500GB + N ° 2 SSD 860 EVO 500GB + WD Blue 2 TB + MSI VENTUS 2X White RTX 4060 8GB GDDDR6 PCI-EX4.0 + ASUS XONAR Phoebus Audio Card Solo 7.1
The problem presented myself by updating from Win11pro 22h2 to 23h2, but also by installing 23h2 from scratch, practically the operating system did not see and did not install the drivers of the I226-V because it was not even detected ;( , I had to reinstall the 22h2 from scratch everything works apparently well for now. Tuf Gaming is a new Asus motherboard, a refresh to better support the new i5/i7/i9-14xxx, maybe my problem is due to a youth of the motherboard and the related drivers. (We hope)
bye
VipeNess
After installing the latest drivers (W11 - 2.1.3.15) on my MSI MPG Z790 Carbon WiFi (https://www.msi.com/Motherboard/MPG-Z790-CARBON-WIFI/support#driver), I've encountered issues with the 2.5GB connection.
While I'm able to maintain a stable connection when plugged into a 1GB port, I experience frequent disconnections and reconnections to the internet upon switching to a 2.5GB port, making it unusable.
  • Service Namee2fnexpress
  • Device IdPCI\VEN_8086&DEV_125C&SUBSYS_7D891462&REV_04\047C16FFFF7BF1D200
  • Revision04
Please advise.
Marmbo
Asus z790-a prime wifi and originally I had random issues with older drivers, 2.5 GB Connection and Win 10 Pro. Some days it would be fine, sometimes it would randomly disconnect/reconnect. After newer drivers 2.1.1.13? Not 100% Sure) those issues went away. I've since gone to a fresh Windows 11 Pro install and have never had connectivity issues at 2.5 GB. I did however turn off power saving for the network connection/device manager settings. Possibly disabling any power management for the network interface may help?
Marmbo
Update: No issues since Going to Win 11 Clean install until yesterday. 07/25/2024 afternoon started having constant disconnects every few minutes for about an hour or so. Reseating network cables didn't help, power management/savings was still off for the ethernet device. After an hour it seemed to settle down and had no issues but then 07/26/2024 disconnection/reconnect after about 45 min. Not sure what changed but was working perfect for months then suddenly a pile of failures. I've set it back to 1GB instead of 2.5 for now as I've never had the issue with this controller on 1GB connection.
2.1.3.15 are the drivers that are in there currently, appear to be from 06/29/2023.
Asus PRIME Z790-A WIFI Motherboard
i9-14900k
Win 11 Pro
VipeNess
Can someone link to me to the latest driver on Intel's website for the Intel(R) Ethernet Controller I226-V?
I've looked everywhere on Intel's website for the drivers and they do not exist: https://www.intel.com/content/www/us/en/support/products/210588/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe/intel-ethernet-controller-i226-series.html
I even tried downloading the 29.0 Ethernet Package and it is not listed nor does it work. https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
I even ran the Intel® Driver & Support Assistant application on my computer and it still does not provide a link next to the ethernet driver like the other components (see below):
I've also seen that there is an issue with this network controller:
https://www.techpowerup.com/303854/psa-intel-i226-v-2-5gbe-on-raptor-lake-motherboards-has-a-connection-drop-issue-no-fix-available
n_scott_pearson
Using this search, I am seeing download for Windows 11 driver here. You can also download the full, everything included, package here.
Hope this helps,
VipeNess
I226-V is not listed on the link for either the Windows 11 driver.
Also the download the full, everything included, does not work either as stated that in my post above.
n_scott_pearson
The lists on the download pages are not necessarily up to date. The Release Notes list the i226 family as being supported.
VipeNess
As you've observed, the release notes indicate support for i226, but upon thorough examination of each folder and file, as well as reviewing the release notes and setup, it's evident that i226 is not supported in the download file. @Cam__Intel Can we get some clarification why it's not included.
Cam__Intel
The drivers for I226 are available in the Complete Driver Pack download.  They are not called out specifically with a container for "I226", but they are in the PRO2500 container/folder.
If you open the .inf file listed below you will see I226 support.
Download the Complete Driver Pack
Unzip the file "Release_29.0.1.zip"
I226 driver files are contain in the following folders:
Release_29.0.1\PRO2500\Winx64\W11  (File:  e2fn.inf)
Release_29.0.1\PRO2500\Winx64\NDIS68 (File:  e2f.inf)
Release_29.0.1\PRO2500\Winx64\WS2022  (File:  e2f.inf)
I hope that answers your question.
VipeNess
Thank you for the clarification. I have switched to using the driver you pointed out and will provide feedback on my experience over the next few days.
To add, the confusion stemmed from the following readme.txt in each folder you shared stating the following:
The driver package supports devices based on the following controllers:
* Intel(R) Ethernet Controller I225
Note that I226 is not listed.
Cam__Intel
It would appear that the readme.txt was never updated.  Thank you for identifying this.  I'll inform our team responsible for the readme and ask them to update it for next release.
Intel
Ruda
Hello.
His WS2022 folder since version 28.3 is rotten.
I installed it on Windows Server 2022. Look at the diagram below. It's not working.
I looked at the properties of e2f.sys in Explorer. You can confirm that you are using an expired certificate. Can it be used normally even if it contains an expired certificate?
[Original Japanese text before Google machine translation]
こんにちは。
バージョン 28.3 以降の WS2022 フォルダーは腐っています。
私は、Windows Server 2022 にインストールしました。下図を見てください。動作していません。
エクスプローラーで e2f.sys のプロパティを見てみました。期限切れの証明書を使っていることが確認できます。期限切れの証明書が含まれていても、正常に使えますか?
VipeNess
@Cam__Intel I had installed the driver from that package (Intel 10/3/2023 - 2.1.4.2) and still getting constant disconnects. I verified that EEE was [OFF]. I can only stay connected via 1GB only.  Please advise.
VipeNess
@Cam__Intel I am still awaiting for an update to this.  This issue is getting really old now and I would like a stable connection.
M4rvin
Hello, I still have the same problem, there doesn't seem to be a solution in sight.
I also noticed the fact that the chip isn't even listed in the driver...
I also have the MSI MPG Z790 Carbon WiFi and it doesn't even run at 1GB.
Operating system still Windows 10
NathanR
Having a similar issue with my ROG STRIX B760-G, i've tried the provided driver from ASUS which is the V2.1.3.15 and the driver pack from intel which contains the V2.1.4.3 and both have the issue, I only notice the dropouts whilst i have games open such as Rainbow 6 Siege or Overwatch 2, and does not happen when just doing some browsing. Event just shows the device as it loses the network contection and re-establishs at 1 gbps full duplex and no over errors.
I have set both on the driver side and on my switch for this to only run at 1 gbps, when both are set to auto, when the issue happens, will flick between 1 gbps, and 100 mbps.
Marmbo
Looks like new drivers just came out Version 2.1.4.3 but I can't find any details on what changed.
VipeNess
Marmbo
I'm using an ASUS Z790-A Wifi motherboard, the download for the driver is off the Asus site for that board. If using a different motherboard I recommend checking the MFGR site.
