Ethernet Products
5536 Discussions
Intel E810-DA2
Diesel
I downloaded following drivers package: ice-1.10.1.2.2.tar.gz from here: https://www.intel.de/content/www/de/de/download/19630/intel-network-adapter-driver-for-e810-series-devices-under-linux.html
This drivers work for 5.10.0-20 but not for 6.1.0-1 or 6.1.0-2. On kernel 6.x I only get a tainted kernel when loading the ice drivers.
Is this a knowing issue?
Irwan_Intel
Hi Diesel,
You may refer to the release notes below for the supported version.
https://downloadmirror.intel.com/762457/Release_Notes_27.8.pdf
Intel Software License Agreement need to be accepted before you could view the file.
Please feel free to contact us should you need any further assistance, and we will be more than glad to continue assisting you.
We will follow up after 3 business days in case we don't hear from you.
Irwan_Intel
Intel® Customer Support
Diesel
thanks but this is no solution.
The 1.10.1.2.2 works for Debian kernel 5.x but when will Debian 11 (Kernel 6.x) will be supported?
Irwan_Intel
Hi Diesel,
Please let me check and get back to you about the supported drivers version on Debian 11.
Irwan_Intel
Irwan_Intel
Hi Diesel,
Upon checking, only kernel 5.x and below supported on the driver version 1.10.1.2.2.
We could install kernel 6.x on Debian 11 but that is using unstable repository while we will only supported on stable releases.
You would probably need to wait for Debian 12 to be supported. Currently, there's no date when updated drivers will be available for that release.
Irwan_Intel
Diesel
ok
